Posted: Thu Aug 01, 2013 11:23 pm Post subject: |
I'm sure I've read somewhere that it's not an easy job to refurbish a servo satisfactorily and it's often a better option to replace them, but it's not something I have any personal experience of. Everything else should be fine to refurb if you can get seals, just have good look at the bores for scoring and so on. It's well worth getting a tub of red rubber grease, use a smear on pistons and pack it under dust caps to try and keep the water out, it might just prevent things seizing up on a car that doesn't see daily use. Calipers, though, can be a pain to get the pistons out of, and old chrome plated pistons will often want replacing as even small imperfections in the plating will damage new seals - if you're not too pushed for cash you might want to pay someone else to do it. Having said that, I never have had the cash for recon calipers and have overhauled at least 3 sets of calipers for different cars with perfect success |
Kelsham
Posted: Fri Aug 02, 2013 9:30 am Post subject: |
I bought a servo kit for my Landcrab It lasted a short time before failing. You need perfect bores, mine was scored slightly.
I purchased a Lockheed replacement, It has been on for at least 12 years.
Regards Kels |
Posted: Fri Aug 02, 2013 9:37 am Post subject: |
cheers kels
going to order a genuine lockheed remote servo from powertrack when i get home from my jollies, brand new, uk made.
http://www.powertrackbrakes.co.uk/
there are a number of lockheed replicas out there it seems! much cheaper but inferior quality
kev |
