Austin Ruby update
petermeachem
PostPosted: Wed Jan 08, 2014 4:53 pm    Post subject: Austin Ruby update Reply with quote
I thought I'd do a bit of an update. The main body is epoxy primed and I'm working my way through the wings, bonnet and doors stripping paint and de-rusting. I have a bit of one wing and the doors to go. Grinding paint off is really laborious and incredibly messy, but I'm getting there. I've just done the first pass on the wings and bonnet, I need to go through and get the deep rust out. Fiddly but I don't end up covered in dust.
These have come out a funny colour in the picture, but they are cleaned up and sitting in a layer of phosphoric acid.
This was what the body was like when I scraped the paint off, so I am making it look better thank goodness
Does anyone have any smart ideas to fix this window?
The other side was repaired before I got the car and has a strip of metal neatly riveted along the lower edge. I'm not sure this one has enough to rivet to. I can't see how to get the glass out. There must be some whizzy modern goo that will do the job.
PostPosted: Wed Jan 08, 2014 5:20 pm    Post subject: Reply with quote
If that is the outside face of the window, what does the inside face look like?
I would think it should have a removeable strip along one of the straight edges, otherwise it would have had to be welded up with the glass in place and that would seem to be a no-no, welding heat and glass wouldn't mix would they?
PostPosted: Wed Jan 08, 2014 5:21 pm    Post subject: Reply with quote
Wow that's a lot of progress, coming along nicely vast improvement, Cool Cool
Steve
PostPosted: Wed Jan 08, 2014 5:59 pm    Post subject: Reply with quote
Thanks for posting the update, always good to see cars as they're improving step by step Smile
Rick (OCC Admin)
petermeachem
PostPosted: Wed Jan 08, 2014 6:11 pm    Post subject: Reply with quote
So would I. It certainly isn't obvious, maybe rivets on the hinge edge. I don't want to take the glass out, that would certainly cause some as yet unknown grief! It's not as though you can buy window frames
petermeachem
PostPosted: Wed Jan 08, 2014 6:32 pm    Post subject: Reply with quote
It is, I'm pleased I have some original pictures so I can see what I've done so far. Still quite a way to go. I've been lucky with the weather, it's been quite mild. My heating in the garage is an Aladdinette paraffin heater, works well but up to an arctic vortex
