Wiring an old stereo
XL391
PostPosted: Fri Mar 21, 2014 5:48 pm    Post subject: Wiring an old stereo Reply with quote
Afternoon all,
As my electrical wizardry can be described as hopeless at best, I would like to ask for some advice if I may.
I have just bought an old Radiomobile 1095X which of course was only intended to power one speaker, one positive lead, one negative lead. If I'm fitting a pair of speakers to it, I am wondering if I attach the 2 positive wires, one from each speaker, to the single positive wire from the system and likewise for the negative set?
Regards,
Will
1972 Daimler Sovereign 4.2 Series 1
1965 Sunbeam Tiger Mk1
1968 Triumph 1300
PostPosted: Fri Mar 21, 2014 7:10 pm    Post subject: Reply with quote
Depends on the speakers impedance. The Radiomobile usually has 1 x 8 ohms so 2 8's connected in series will give 16 Ohms which will reduce volume.
If connected in parallel then 2 8's = 4 Ohms which may be too little and overload the amplifier though these radios are quite tolerant.
2 x 4 Ohms speakers in series via a balance control is better than 2 x 4 in parallel I think but radio experts will definitely know for sure.
Both must be equal though.
Most modern speakers are 4 Ohms
Rover P2
Morris Mini Traveller Mk2
XL391
PostPosted: Fri Mar 21, 2014 11:29 pm    Post subject: Reply with quote
Very helpful Phil, thank you for your reply. I'll try and avoid the fireworks show tomorrow... Wink
Regards,
Will
1968 Triumph 1300
PostPosted: Sat Mar 22, 2014 12:09 am    Post subject: Reply with quote
Rovers eg P5B's of the late 1960's & early 1970's had the Radiomobile 1095X which powered easily a front and large rear speaker via a double gang fader on the rear heater control panel on the transmission.
The tone and volume is excellent with the rear speaker full on and the front just down
Rover P2
XL391
PostPosted: Thu Apr 03, 2014 8:25 pm    Post subject: Reply with quote
All installed now! I went for connecting them in series with the 2 speakers, one in either door without a balance control. My thanks go Phil for his help and advice.
Regards,
Will
1968 Triumph 1300
