1stpop
Posted: Fri May 02, 2014 7:30 pm Post subject: Distributor |
Can anyone point me in the direction of a reliable distributor supplier?
The hand book for my Hillman Minx series lllb says I need a Lucas DM4P2
any suggestions would be greatly appreciated - the original is a wreck - not even servicable |
Posted: Fri May 02, 2014 9:27 pm Post subject: |
why dont you speak with an electronic ignition expert, good time to upgrade?
Kev |
Posted: Sat May 03, 2014 6:45 am Post subject: |
Have you tried the Distributor Doctor - he may be able to suggest an alternative if he cannot fix it _________________ Rover P2
Joined: 23 Nov 2007 Posts: 4104 Location: South Cheshire
Posted: Sat May 03, 2014 9:25 am Post subject: Re: Distributor |
1stpop wrote: | Can anyone point me in the direction of a reliable distributor supplier?
Are you sure it's not a Lucas DM2P4? If so a very common unit fitted to loads of vehicles.
PS
Just looked it up, it is a DM2P4 Lucas part number 40492A/B |
1stpop
Posted: Wed May 07, 2014 12:00 am Post subject: |
thanks it is a DM2P4 - and the cause of all my problems!!!!! |
pmarshal
1stpop
Posted: Sat Jun 14, 2014 1:54 pm Post subject: distributor |
Sent it off in May - just found out it will take 8/9 weeks.
Any suggestions where I can get a replacement? going to miss all the local shows!!
Is there an alternative to the DM2p4? |
Posted: Sat Jun 14, 2014 2:39 pm Post subject: |
had the same problem a week or so ago
speak with accuspark
http://www.accuspark.co.uk/index.html
They list one suitable for the minx.
I fitted one of their distributors a couple of weeks ago following ignition failure, Delivered next day for £58 (complete distributor). Took about 10 mins to set up and get running perfect, to be fair, best £58 spent on the car so far.
Kev |
1stpop
Posted: Sat Jun 14, 2014 9:45 pm Post subject: |
cheers - what car is it - just out of interest? |
Posted: Sat Jun 14, 2014 9:46 pm Post subject: |
1stpop wrote: | cheers - what car is it - just out of interest? |
Mine? singer vogue mk3
Kev |
