Progress Report on my Renault Ondine in Bolivia
richardlw
PostPosted: Tue Jan 01, 2013 12:11 am    Post subject: Reply with quote
Back in Tarija and got some pics at the body shop this morning. He has done a nice job of replacing the left side frame, rockers and sills. The doors actually close now that it is not sagging.
Now he has been working on the right side, where he had to replace a long section of the rail, then rocker, and then will be putting the final sills on.
He has been cutting up some Toyotas, Nissans and Mitsubishis for steel. Once the rockers and sills are done, he will cut out the front floor and replace it.
Richard's Cars - NEW **
Motor oil for Flat Tappet Engines
Transmission oil
richardlw
PostPosted: Thu Jan 10, 2013 12:46 am    Post subject: Reply with quote
Chassis and rocker panels are all replaced/repaired, so now we move on the floor panel replacement.
Details of the chassis and rockers are here: http://www.widman.biz/Dauphine/English/progress/m20.html
Transmission oil
richardlw
PostPosted: Fri Feb 22, 2013 3:49 am    Post subject: Reply with quote
I haven't been able to get away to Tarija, but finally got some more pics from the body shop. He finished the floor and has it and the trunk in primer. When finished I'll put fatmat on the floor.
Transmission oil
JC T ONE
PostPosted: Fri Feb 22, 2013 7:41 am    Post subject: Reply with quote
The car is really coming on nicely Cool ´
PostPosted: Fri Feb 22, 2013 8:08 am    Post subject: Reply with quote
Agreed, it's very interesting to follow progress from the first photographs through to now Smile
richardlw
PostPosted: Sun Jun 15, 2014 1:22 pm    Post subject: Reply with quote
A little more to add. This one has not been my priority, concentrating on the Mini, and I've had little time, but I finally picked up and assembled the front spindles that I had made a a machine shop, assembling the front brakes and all in the body shop.
Then got a new set of seats from a friend in Argentina who shipped them by bus. I stripped them, welded a couple of spots, painted and gave them to my upholsterer, who is now close to finishing.
Transmission oil
richardlw
PostPosted: Thu Jul 09, 2015 1:12 am    Post subject: Reply with quote
Finally back to work on the Renault in the body shop
I also took a day to take out the dents and polish up the stainless windshield and rear window trim
Almost straight
Transmission oil
JC T ONE
PostPosted: Thu Jul 09, 2015 4:35 am    Post subject: Reply with quote
Looking good Cool
richardlw
PostPosted: Sat Aug 13, 2016 12:52 am    Post subject: Reply with quote
Finally have something significant to update. I got my body guy working on it, and we now have it painted. Working on reassembly now. I had to make the springs for the front doors, and re-chromed the hood hinges, straightening and re-chroming the Bumpers. I've also located the two new wheels I need (in Sao Paulo) and they should be here in a couple of weeks. I also located 5.60-15 tires, and will be taking my hub caps to be re-chromed next week after some straightening. I also pulled the dash apart, painted it a brown to match the upholstery, polished up the trim, etc.
Transmission oil
PostPosted: Sat Aug 13, 2016 8:39 am    Post subject: Reply with quote
This Renault is going to look amazing. Thanks for posting all the progress photos. It's great to see it.
norustplease
PostPosted: Sat Aug 13, 2016 11:01 am    Post subject: Reply with quote
Brilliant, I haven't seen one of these for years, in fact the family had several Dauphines in their heyday. You could get these almost off the peg, whereas a Ford Anglia had something like a 6 month waiting list. My uncle had a small rural garage in Lincolnshire, he bought several and sold them around the family. Ours was red and a Gordini spec.
It was the first truly reliable car that we'd had and never missed a beat, although rust got it in the end.
1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV
richardlw
PostPosted: Sat Aug 13, 2016 3:24 pm    Post subject: Reply with quote
Yep, as you said: Rust! They did not use very good quality steel, and with the unibody, that did in a lot. Also poor steel in the water distribution tube that rusted quickly if you did not use coolant, resulting in overheating.
Transmission oil
richardlw
PostPosted: Fri Jun 30, 2017 12:15 am    Post subject: Reply with quote
When I finally got back to Tarija I got going on the assembly. Good to have the car at home where I can work on it a few hours at a time, as time permits.
First I set out to restore and assemble the steering column controls (bought used), steering wheel, and dash parts.
[img]http://www.widman.biz/Renault/M68/steering-wheel patched.jpg[/img]
Then time to assemble the bumpers and align them, making a new joint cover from stainless steel.
One of the side vents that I bought "restored" did not meet my standards, so I sanded it and polished it.
Also went through the inside, painting everything with an anti-corrosive and then covering with Fatmat for sound absorbance.
Then filled the sprayer anti-corrosive and then with undercoating, taking care of the undercarriage.
Turning to the electrical, the wiper arm pivots were stuck, so had to be taken apart and cleaned, lubed, etc.
For the wiring I ripped out everything and started over with an assortment of wires and terminals from my local electrical supply store and a nice panel from Racers Inc that included the relays, fuses, and about everything in one place.
With the wires run I installed the radiator and it's side panels that divide the engine from the firewall, discovering a couple of small cracks in one of the supports, so a little welding was in order, then the install with the new spout that I had to correct rom manufacturing defects.
Then I remembered I had done nothing with my gas tank, so cut the bottom part off and fabbed a new bottom out of an old fender from the body shop, cleaning everything up with phosphoric acid and sealing it inside with epoxy.
I'd like to say it is running, but I found that my supposedly rebuild starter was not rebuilt, so it is being rebuilt. I leave you with some pics of the engine compartment before and after.
Transmission oil
PostPosted: Fri Jun 30, 2017 6:56 am    Post subject: Reply with quote
Amazing considering how it was when you started the job. Great work well done all Cool Cool
PostPosted: Fri Jun 30, 2017 7:48 am    Post subject: Reply with quote
Wow, thanks for posting your updates, amazing job Cool Cool
Page 2 of 4
