Penguin45
Posted: Wed Nov 12, 2014 1:30 am Post subject: Girling Powerstop IIB remote servo. |
Bit of an off the wall question, and I'm not really expecting an answer, but if you can, I'd be grateful.
I have two of these, one an original fitment on the car, meaning that it's a congealed block of rust; and one which has been "serviced" before, as it has the screw clamp band around the vacuum housing rather than the clamp band.
Taking the path of least resistance, I stripped the one with the clamp band, removed the pistons and noted that the ball bearing in the anti-knock piston was absent.
On to unit two - an immense, titanic struggle ensued to remove the pistons (I've had to buy a new can of Plusgas). When the anti-knock piston came free, the ball bearing shot over my shoulder, hit the wall on the far side of the garage and will (obviously) never be seen again..........
So - does anyone know how big that ball bearing is? It ain't going to work properly without it and the highly detailed Girling technical data decribes it as "ball bearing".
Got a lovely little transmission place local to me who will probably provide a new ball (albeit with much tutting) if we can work out the size..
Thanks,
Posted: Wed Nov 12, 2014 2:22 am Post subject: |
I'm guessing, but wouldn't it be the same diameter as the 'propulsion' spring?
Posted: Wed Nov 12, 2014 4:01 am Post subject: |
Sorry to hear you lost your ball. |
Posted: Thu Nov 13, 2014 1:45 pm Post subject: |
Ditto to kevin2306 comment! |
Penguin45
Posted: Sat Nov 15, 2014 2:15 am Post subject: |
Had a brief chat with those nice chaps at Powertrack, who couldn't really advise me, although they were very interested in selling me the recon kit.
I trundled down to Atlantic Bearings with my anti-knock piston and a bit of measuring and logic ensued. Problem solved for pennies.
Cheers,
