commer vc brake pedal
chewie
PostPosted: Thu Nov 06, 2014 5:36 pm    Post subject: commer vc brake pedal Reply with quote
Does anybody know if the brake pedal sits lower ie not level with the clutch pedal.
As i thought mine was stuck down but after some investigation it looks like it should be where it is .
i have successfully managed to get air in the system and have now got some brakes just not to sure about the pedal as there is not a lot of travel?
PostPosted: Thu Nov 20, 2014 2:16 pm    Post subject: Reply with quote
Not sure how yours is linked but on the older Commers the pedal has a rod linkage to the actuator on the side of the chassis. The pedal can be adjusted by means of a nut on the end of he linkage. I would say from memory that the pedals are roughly level.
