JC T ONE
Posted: Tue May 19, 2015 2:05 am Post subject: Wanted |
Hi all,
is there anyone inhere that can help with one (or more) of the following parts.
1 - a Lucas Black rubber cover, for a std Lucas negative helmet connector.
2 - a sound insulation blanket in Silver / Grey vinyl, with diamond shaped pattern. Looks like one of them old radiator / grill winter Muffs.
3 - a round exhaust silencer, with roll welded ends, and the in & out pipes (small = std Mini) positioned in different height.
4 - some Blue floor mat for a Austin/Morris 11/1300 = ADO 16 .
Thanks for looking.
Jens Christian
Here you go Rick = jc(AT)showcars.dk
phone 0045 51304698 _________________ http://www.eurods.eu/wp/index.html
JC T ONE
Posted: Tue May 19, 2015 12:33 pm Post subject: |
Done _________________ http://www.eurods.eu/wp/index.html |
JC T ONE
Posted: Tue May 19, 2015 2:37 pm Post subject: |
Now here I opened my mailbox expecting it to be full of replies - and found nout.
Hmm better add some more "common" items to it then
I am also looking for 4 crossply tyres with White walls size = 10" .
used are also of interest.
Jens Christian _________________ http://www.eurods.eu/wp/index.html |
bob2
Posted: Wed May 20, 2015 10:06 am Post subject: |
Don't put white walls on a mini Jens, never liked them myself!!!
I'd much prefer it with a set of reverse rims on!! |
JC T ONE
Posted: Fri May 22, 2015 1:18 am Post subject: |
bob2 wrote: | Don't put white walls on a mini Jens, never liked them myself!!!
Hi B2,
Probably not a big chance to find any but rest asured = I will fit them if i found 4 and it will stay on its narrow std rims, with std hub caps
Just bought a used but original rear subframe from Califfen _________________ http://www.eurods.eu/wp/index.html |
JC T ONE
Posted: Mon May 25, 2015 12:34 am Post subject: |
New item added to my wants list.
A Lucas switch dated 9.61 - 10.61 or 11.61 - only need the switch.
Thanks _________________ http://www.eurods.eu/wp/index.html |
bob2
Posted: Mon May 25, 2015 8:43 am Post subject: |
I do need a couple of toggle switches too, but not too fussed about the year!!
I admire your attention to these small details though! |
JC T ONE
Posted: Wed Jun 10, 2015 2:28 am Post subject: |
bob2 wrote: | I do need a couple of toggle switches too, but not too fussed about the year!!
Today I polished & fitted the 6 sided nut I got from a Mini friend Friday.
I can now paint the White nylon housing, and have the correct look, once its fitted to the panel. _________________ http://www.eurods.eu/wp/index.html |
