Edward Turner
JC T ONE
PostPosted: Sun Jun 28, 2015 2:08 pm    Post subject: Edward Turner Reply with quote
Hi all, I bought myself a new "toy" but unfortunally is a few parts missing.
Hope to locate the parts, so I can get it started.
62rebel
PostPosted: Sun Jun 28, 2015 3:36 pm    Post subject: Reply with quote
nice start!
nothing is ever so far gone as to be unsalvageable. see this bolt?.....
PostPosted: Sun Jun 28, 2015 5:29 pm    Post subject: Reply with quote
Daimler V8?
JC T ONE
PostPosted: Mon Jun 29, 2015 2:49 am    Post subject: Reply with quote
62rebel wrote:
nice start!
Thanks Smile
JC T ONE
PostPosted: Mon Jun 29, 2015 2:50 am    Post subject: Reply with quote
badhuis wrote:
Daimler V8?
Correct = 2.5 Hemi from a saloon.
JC T ONE
PostPosted: Wed Jul 01, 2015 4:34 am    Post subject: Reply with quote
Spend a little time with the engine tonight.
Took all sparkplugs out & cleaned them.
Sprayed all cylenders with WD40.
Then it was time to see if she would turn ?
First she was a bit "tight" (used a lever on the ring gear) so I sprayed some WD40 on both crank ends.
After a while I switched the lever with a spanner on the front of the crank. Then oil startet coming around the engine, and it loosened up.
I then sprayed some more WD40 into the bores, and left it alone, so it can "go to work" .
Hope to start it when I have found the missing manifold.
PostPosted: Wed Jul 01, 2015 7:17 pm    Post subject: Reply with quote
Rick has found the shirt that you could sew onto your button!
Admittedly it's not missing a button but that's just a detail.
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=17435
Peter Wink
JC T ONE
PostPosted: Sat Jul 04, 2015 1:41 am    Post subject: Reply with quote
Yepp - sweet Cool
