spitfirebob
Posted: Tue Jun 21, 2016 6:38 pm Post subject: |
petelang wrote: | Did your engine builder not run test the engine?
I just wonder if they taped over the manifold holes and forgot to remove it when fitted?
Peter |
No,they just rebuilt engine without a test bed |
spitfirebob
Posted: Tue Jun 21, 2016 6:40 pm Post subject: |
Rick wrote: | Does it improve as it warms up?
RJ |
There's no noticeable change when warm |
ALW Ford Popular
Posted: Thu Jun 23, 2016 8:18 pm Post subject: |
Thinking about this - any chance they got the timing out on the crank / cam via chain? A few teeth out perhaps?? |
spitfirebob
Posted: Sat Jun 25, 2016 2:52 pm Post subject: |
Right,after changing all ignition pates still the same!!
But have noticed that carb seems to be throwing alot of fuel in so much so that when I open throttle a mist of fuel comes out of top cover
Also air mixture screw doesn't make a difference in any position and even fully removed!
Could this actually be causing all my problems?? Something isn't right somewhere in carb so could lack of power be caused by overfuelling? |
Kenham
Posted: Sat Jun 25, 2016 3:42 pm Post subject: |
Sounds like the choke is not returning properly. |
Posted: Sat Jun 25, 2016 4:09 pm Post subject: |
Bob,
Have you checked the float in the carb.? Take out and give it a shake to see if there is any liquid inside. Also check the needle and seat adjustment. It sounds like the fuel level is too high.
spitfirebob
Posted: Sat Jun 25, 2016 5:52 pm Post subject: |
Battle recommences in the morning then! Strip carb down and recheck everything |
Posted: Sat Jun 25, 2016 6:50 pm Post subject: |
spitfirebob wrote: | Right,after changing all ignition pates still the same!!
If the mixture adjustment makes no difference I'd still wonder about it drawing in air somewhere it shouldn't be, making it run hyper-lean. What colour are the plugs?
I remember on my E83W, revving the engine while peering into the top of the carb (air inlet, cover removed) you could see a mist of fuel splurt across. Normal stuff iirc.
spitfirebob
Posted: Sat Jun 25, 2016 7:31 pm Post subject: |
Rick wrote: | spitfirebob wrote: | Right,after changing all ignition pates still the same!!
RJ |
Plugs are quite black!
It's not a fine mist across the chamber it actually wets my hand working the throttle |
spitfirebob
Posted: Mon Jul 11, 2016 6:53 pm Post subject: |
Have changed the carb and overfuelling problem still there
Could fuel pump be the cause? |
Joined: 23 Nov 2007 Posts: 4755 Location: Swindon, Wilts.
Posted: Mon Jul 11, 2016 9:19 pm Post subject: |
These carbs don't have the accelerator pump do they? _________________ Bristols should always come in pairs.
Posted: Mon Jul 11, 2016 10:48 pm Post subject: |
spitfirebob wrote: | Have changed the carb and overfuelling problem still there
I'd be surprised if it was (assuming it's the standard mechanical pump, bolted to the side of the block), in theory the pump only supplies what the needle valve (& float) allow it to pump into the float chamber.
As I've mentioned before, I remember being able to see fuel splurt across when peering into the carb as the engine was revved on my E83Ws, but never enough to drown the engine or mist/spray out above the carb's air intake while running.
Are you able to post up any photos of the engine, carb, and so on, just in case something obvious is in evidence? Even a video uploaded to somewhere online might be very useful.
spitfirebob
Posted: Fri Sep 02, 2016 8:51 pm Post subject: |
Sorry for not replying to anybodys posts but got fed up with car and had a break from it for a few weeks, but....Got it running at last!
Turns out that engine builder had set timing about 2 1/2 teeth out
Runs lovely and smooth now |
