Air filter for Morris eight
MattF
PostPosted: Sat Jul 01, 2017 9:38 pm    Post subject: Air filter for Morris eight Reply with quote
Anyone fitted a air filter to a s1 Morris 8? What sort did you use? Can one be fitted to the end of the air silencer or do you have to take that off?
bjacko
PostPosted: Tue Jul 04, 2017 5:02 am    Post subject: Air Silencer Morris 8 Reply with quote
An air silencer already exists on most Morris 8's to which you can attach an air filter. I fitted one and it has not affected the performance. A number of others have also fitted them directly on to the carby.
PostPosted: Tue Jul 04, 2017 1:01 pm    Post subject: Reply with quote
MattF
PostPosted: Wed Jul 05, 2017 10:48 am    Post subject: Reply with quote
Hi Peter, I have the air silencer just not sure how I could fit a filter in the end of it. Could you put up a photo off yours with the filter on please? In an ideal world I'd like to have a way I can fit a filter on the air silencer and then easily take it off when I want it to look right, just not sure how that could be done.
PostPosted: Fri Jul 07, 2017 9:23 am    Post subject: Reply with quote
Sorry Matt, I don't have a Morris 8, only memories of my big sister's one that she had 50 years ago and I can remember that it didn't have its air silencer either! Sad
Here's a photo of the carb connection but it might be quite a tricky part to fabricate although still possible if you weren't too fussy about replicating the original.
bjacko
PostPosted: Sat Jul 08, 2017 7:12 am    Post subject: Morris 8 Air Filter Reply with quote
I cannot see an air filter in the photo, maybe Peter thinks the air silencer is an air filter. I was trying to upload a photo of my air filter but cannot get the useless Photobucket to work.
PostPosted: Sat Jul 08, 2017 8:54 am    Post subject: Reply with quote
I could be wrong but as far as I know there never was an air filter (as we now think of one) in the Series 1 Morris 8. I just assumed that Matt was using the term loosely to cover "that thing wot is attached to the carb intake"
Later cars did have a filter.
See also: http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=14232
PostPosted: Sat Jul 08, 2017 4:32 pm    Post subject: Reply with quote
Correct Peter
The only air filter fitted to Morris 8's was to the later Series E, and then only the "Export" models, Morris must have considered that these foreign roads were dustier than our British ones!
If you a MR member there is a topic on the forum about fitting air filters to 8's.
MattF
PostPosted: Sun Jul 09, 2017 6:42 am    Post subject: Reply with quote
Your all right, I'm just wanting to put a filter on because quite often our club will do runs on dusty back roads and in the interest of making sure she's still running in another 80 years I'm wanting to protect her as much as possible.
Still working on ideas so if anyone else has some let me know Smile
PostPosted: Sun Jul 09, 2017 9:27 am    Post subject: Reply with quote
If you can't track down the Series E export job you could always try post 6 here: http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=14232&postdays=0&postorder=asc&start=30
