RogerB
Joined: 18 Dec 2014 Posts: 177 Location: Suffolk Coastal. U.K.
Posted: Tue Jun 19, 2018 11:20 am Post subject: Wanted- Standard 8 Petrol Pump |
Has any one got one of these mechanical petrol pumps spare?
The one from my 8 is cracked on the petrol inlet side and, being made in Marzac (?) is irreparable.
RogerB email roger 9 5 6 brown at hotmail dot co dot uk |
RogerB
Posted: Tue Jun 19, 2018 5:21 pm Post subject: Standard 8 petrol pumps |
I bought one and fitted it; when it was on the bench the vacuum pressure was 10lbs. When I fitted it to the Standard it would not work at all.....
RogerB |
Posted: Tue Jun 19, 2018 6:17 pm Post subject: |
Is your fuel line from the tank free of blockage?
Connect the pump to the fuel line but operate the lever manually (not attached to the engine) and without connecting it to the carb. and check if fuel comes through. If not use an air pump to blow down the fuel line from the engine compartment then try manually to operate the pump again.
RogerB
Posted: Sat Jul 07, 2018 8:34 pm Post subject: |
Finally my Standard 8 is running....
I bought a recon. kit for the pump and managed to get an old workable pump from a fellow '8' owner. A friend who understands these things better than me assembled my original pump with the new 'bits' and,hey presto, the pump works with all the right pressures showing at the right places.
Thank you Phil.....!
RogerB |
