Joined: 23 Nov 2007 Posts: 4755 Location: Swindon, Wilts.
Posted: Mon Jul 09, 2018 6:46 pm Post subject: |
hi
Not the bus. It might have been posted on a bus enthusiasts site but they often go car and van spotting on these street scenes. _________________ Bristols should always come in pairs.
Posted: Mon Jul 09, 2018 8:19 pm Post subject: |
It's the Cowley on the right.
I took it to be a commercial version with a painted grille, a typical giveaway. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Mon Jul 09, 2018 8:26 pm Post subject: |
Penman wrote: | Hi
This one isn't so much a mystery but apparently there is a rarity on here.
It is on an SCT61 thread.
I didn't know which it was and to stop cheating I have blocked out the exact thread link and the bus reg.
I can't see any rarity. Can you point it out.
Not the A70 in the foreground?
Or was it that MO behind it ?
Posted: Mon Jul 09, 2018 8:45 pm Post subject: |
MV got it, it's not an MO it;s a saloon version of the Cowley.
http://www.sct61.org.uk/lgjua763a _________________ Bristols should always come in pairs.
Joined: 31 Jul 2009 Posts: 1773 Location: Market Warsop, Nottinghamshire
Posted: Mon Jul 09, 2018 8:48 pm Post subject: |
I think the odd thing with the MO is that it appears to have a curved top to the door window frame (or maybe that's a curve on the railingsbehind, in which case the door window is frameless!); the rear side window shape also looks a bit odd; maybe some sort of 2-door coupe? _________________ in the garage: 1938 Talbot Ten Airline
Posted: Mon Jul 09, 2018 8:57 pm Post subject: |
No, Penman, it's not a Cowley! The 1200cc Cowley version was introduced in July 1954 based on the Mk2 Oxford. These earlier MOs were all Oxfords (or LCVs). This is an early car with the pre-1952 grille, or perhaps a Martin Walter conversion on the van base, which retained this grille style.
edit: OUM is a 1951-52 Leeds registration, so I reckon it's a standard Oxford. _________________ in the garage: 1938 Talbot Ten Airline
Posted: Fri Jul 13, 2018 9:09 am Post subject: |
Looking for coal scuttles with 4 louvres I came across this De Dion Bouton. (Z type ??)
Not very similar otherwise I must admit.
Posted: Sat Jul 21, 2018 6:36 pm Post subject: |
I think you are right, Peter. I would also say De Dion Bouton Z type (8hp).
One thing about these veterans I have noticed is that the oblong radiator mounted with brass surround and script seems to vary from one car to another. It would be interesting to know if, originally, the cars just had a couple of finned pipes for cooling as this seems to have.? |
Penguin45
Posted: Wed Aug 29, 2018 4:32 pm Post subject: |
Any of you chaps able to take a punt on what this might be?
UIWolseley. by Penguin 45, on Flickr
Have been contacted as the chap thinks it may be a Wolseley but it doesn't match any of my records. Looks a bit Morrisy around the radiator to my eye.
Thanks,
Posted: Wed Aug 29, 2018 4:56 pm Post subject: |
If the car behind is any sort of a clue, I would say it might be a Singer.
Singer Senior |
