Austin Seven Ruby ARQ rejuvenation
Goto page Previous  1, 2, 3 ... 10, 11, 12
PostPosted: Sun Nov 25, 2018 7:26 pm    Post subject: Reply with quote
Great to see you back here again, and continuing with the in-depth posts - inspiring stuff.
Rick (OCC Admin)
OuBallie
PostPosted: Tue Nov 27, 2018 1:34 pm    Post subject: Last update for a while Reply with quote
NS Inner Arch/Tappets/AGDO
Rick,
Thanks for the welcome back, it does feel GOOD!
4th February I had occasion to use the 111 service as I thought I was passing kidney stones due to the pain in my left kidney, but not the writhing on the floor type that my Nephew experienced when he had stones.
The OOHs doctor turned up after 2 hours and diagnosed a severe waterworks infection. The PH strip was bright red.
It took three lots of antibiotics, the last a different lot that did the trick.
It was then 6 trips to hospital over the next 3 months, the last being overnight, for all sorts of tests and scans.
All where negative thank goodness, BUT the whole experience had a rather negative effect on me in that I lost interest in just about everything due to loosing any 'get up and go' energy.
That was THE most frustrating part during the months that followed, and only now am I coming back to being 'normal'.
Another update and the last for a while.
Missed these with the NS rear inner arch
Grinding Tappets
The valve stems had made a perfectly round indentation in them that would make it nigh on impossible to set the gaps.
Something had to be done, and not having either a surface grinder or a working toolpost grinder (I need to sort it out) I came up with the perfect Heath Robinson method.
I used my high speed drilling machine and Dremel type grinding wheel, and slowly moving the vice backwards and forwards.
After finishing on the drilling machine I finished off with a few rubs on the fine diamond abrasive.
Ready to assemble to see if valve stems making even contact.
Yes they do, and Heath Robinson winning the day once again.
AGDO
(Angle Grinder & Drill Organiser)
I got sick and tired of searching for the one with the correct disk so decided it was high time I pulled finger and did something about it.
I had all the parts and the vice stand pipe was part of the sign.
Rear of sign the perfect spot to hang disks from.
Geoff - That's it for some time folks.
Too many hobbies, not enough time!
1935 Austin Seven Ruby ARQ
1957 Austin A35 2-door
1967 Morris Minor 2-door
Model Engineering
peterwpg
PostPosted: Tue Nov 27, 2018 1:42 pm    Post subject: Reply with quote
Good to see the posts again Geoff.
Question ? Grinding the valve tappet heads, are they not case hardened ?
Peter L
PostPosted: Tue Nov 27, 2018 4:17 pm    Post subject: Reply with quote
Good idea to hang the angle grinders!
OuBallie
PostPosted: Wed Nov 28, 2018 12:05 pm    Post subject: Reply with quote
Peter,
Yes they are.
Did a test using a file, and it just skated over the surface.
badhuis,
Why do we sometimes take ages to sort things out?!
Geoff - Next video will be the sliced later cylinder block.
Model Engineering
OuBallie
PostPosted: Thu Dec 06, 2018 9:29 pm    Post subject: Reply with quote
Peter,
Yes they are.
badhuis,
Model Engineering
PostPosted: Thu Dec 06, 2018 10:32 pm    Post subject: Reply with quote
The ghost in your computer has re-posted 6 days later.👻
peterwpg
PostPosted: Fri Dec 07, 2018 5:23 pm    Post subject: Reply with quote
Not a ghost, the repeat is for the benefit of the visually impaired. Confused
Peter L
MooiMeisie
PostPosted: Sat Aug 17, 2019 11:47 am    Post subject: Overdue update Reply with quote
NS B-Post repair.
NS Flitch Panel
Patch cut out
Was getting ready to do the necessary with bits of metal to do the repair, when it all came to a shuddering halt!
Geoff - ‘The best laid plans of mice and men’ springs to mind
MooiMeisie
PostPosted: Sat Aug 17, 2019 11:53 am    Post subject: Progress hit the buffers! Reply with quote
31/07/2019
Had tilted the car to where it was comfortable to work on the NS Flitch plate, then some 10 minutes later found myself in an Ambulance with Blues & Twos going full bore.
25 odd minutes later, I wasn’t keeping count, I was in the CCU Theatre at NNUH for an emergency stent.
I have always had a morbid curiosity as to what it was like to be in an Ambulance with lights and siren going, and being fully awake found it quite interesting, and can only give a thumbs up at the way the lady Paramedic driver performed in getting the Ambulance through traffic with little discomfort to me.
Only once did she have to brake really hard, no doubt due to some moron driver.
Road noise drowned the siren a number of times
The episode took place on the 31 July, was back home on the 6th so in recovery mode, BUT feeling quite well considering.
The number of tablets I now have to take is eye popping, so had to buy a week organiser for AM/PM otherwise utter chaos would have resulted.
Geoff - Took the wrong tablets once, before the organiser arrived 🤗
PostPosted: Sat Aug 17, 2019 2:31 pm    Post subject: Reply with quote
A lucky escape Geoff. Only a couple of days ago I received word of a friend the same age as me who had died of a heart attack. We used to go hill walking together and he appeared totally fit and healthy. A real shock and a timely reminder that health can very rapidly go wrong without warning. I will be attending his funeral next week.
Peter Shocked
PostPosted: Sat Aug 17, 2019 3:05 pm    Post subject: Reply with quote
Glad to hear that you're on the mend, Geoff.
Keith
1926 Chrysler 60 tourer
1950 Austin A40 tourer
1999 BMW Z3
PostPosted: Sat Aug 17, 2019 9:24 pm    Post subject: Reply with quote
Geoff,
What a crazy coincidence, I was in my garage plodding about yesterday and it crossed my mind that we hadn’t heard from you in a while and here you are. I hope you have a speedy recovery and return with your reports in the fullness of time.
Best regards
Art
Page 12 of 12
