Home made spark test gap block
DM
PostPosted: Sat Dec 29, 2018 1:26 pm    Post subject: Home made spark test gap block Reply with quote
I have been looking out for a 3 electrode ignition spark gap block for ages,
could not find one to buy so made my own.
PostPosted: Sun Dec 30, 2018 10:52 am    Post subject: Reply with quote
What use does this have?
PostPosted: Sun Dec 30, 2018 12:34 pm    Post subject: Reply with quote
This isn't something I've come across before, I'd be interested to know more about it.
DM
PostPosted: Sun Dec 30, 2018 12:51 pm    Post subject: Reply with quote
When bolted to this 50's Octopus test bench -
I can test run a magneto from 0 to 6000rpm, which means I can check-
Minimum speed the mag will spark at
The advance curve
Points bounce
Wear on cam to make sure all cylinders are timed right
Spark voltage
I can also warm the mag up to make sure it still sparks when hot
The Octopus can test dynamo's, alternators and starter motors as well
PostPosted: Sun Dec 30, 2018 5:31 pm    Post subject: Reply with quote
Very interesting, not unlike the rig that my mag was tested on a few years back.
Rick (OCC Admin)
RogerB
PostPosted: Sun Dec 30, 2018 9:50 pm    Post subject: Octopus test rig Reply with quote
DM,
I write articles for several classic car club magazines and I would like to write about the test rig you have. Is it possible I could have a photo of the rig and a bit of information about?
Thank you,
RogerB
PostPosted: Sun Dec 30, 2018 11:18 pm    Post subject: Reply with quote
This was the unit that little Dodge's mag was tested on, you can just see one spark jumping between a pair of contacts
Rick (OCC Admin)
DM
PostPosted: Mon Dec 31, 2018 12:12 am    Post subject: Re: Octopus test rig Reply with quote
RogerB wrote:
DM,
Thank you,
RogerB
Roger I have a bit more work to do making up a set of leads befor it is useable, once I have that done I'll take some photo's and sort some info out.
In the meantime here is a pic of the complete set up.
alanb
PostPosted: Mon Dec 31, 2018 10:39 am    Post subject: Reply with quote
What a wonderful piece of kit, looks like it should belong in a 50s sci fi film
old tourer
Morris 8 two seater
RogerB
PostPosted: Mon Dec 31, 2018 5:03 pm    Post subject: Reply with quote
DM,
A very impressive piece of equipment.....!
Any chance of emailing me a copy of the photo please; I feel an interesting article coming on.....!
RogerB
