3 jaw chuck quandary
Kleftiwallah
PostPosted: Mon Aug 06, 2018 6:53 pm    Post subject: 3 jaw chuck quandary Reply with quote
Good afternoon everyone, I'm having a problem giving my Myford 3 jaw chuck an overhaul. After dismantling and looking for any identifying marks, cleaning out the old grease and inspecting all parts for wear, everything is fine.
The rebuild. I've sparingly coated all parts with new clean grease and on initial rebuild everything is fine, until I tighten the six screws the last turn.
The chuck startes to tighten up and with the screws fully tight the chuck is hard to operate. The only thing I can think of is the three fluted gears are site specific but I'm kiggered if I can find any marks to line up with the semi circular slots.
Over to you knowledgeable ones. Cheers, Tony. Confused
It may work in practice, but not necessarily in theory!
consul 57
PostPosted: Mon Aug 06, 2018 7:41 pm    Post subject: Reply with quote
the jaws need to go back in the right slots, my chuck has 1,2 & 3 on each jaw
peterwpg
PostPosted: Mon Aug 06, 2018 8:50 pm    Post subject: Reply with quote
I used to have a lathe, with a 4 jaw. All the pieces were stamped and the only way to assemble was the right way.
https://www.youtube.com/watch?v=CP6tW2ge2xs
Re-assemble before fitting the jaws.
Peter L
PostPosted: Mon Aug 06, 2018 9:19 pm    Post subject: Reply with quote
yep they are usually numbered
Kleftiwallah
PostPosted: Mon Aug 06, 2018 9:27 pm    Post subject: Reply with quote
The problem isn't with the three jaws, the problem is when I close the two segments of the jaws (minus the threaded portion that afixes the chuck to the lathe) with the three fluted jaw adjusters in position.
These two parts are held together by 6 slotted cheese headed screws, when thses screws are finally nipped up the chuck key is difficult to turn (this is before entering the 3 jaws into their respective slots). I thought I made it clear the problem wasn't with these 3 jaws.
Cheers, Tony.
peterwpg
PostPosted: Mon Aug 06, 2018 9:51 pm    Post subject: Reply with quote
In the you tube link, at the end there is the reassembly. There is no grease used just a thin coating of oil. A good chuck is very precise and even a few thou layer of grease can affect assembly. Grease doesn't compress.
Peter L
Kleftiwallah
PostPosted: Tue Aug 07, 2018 10:33 am    Post subject: Reply with quote
In the you tube display I watched he was slapping grease on with a paintbrush!
Not really an answer to the initial problem, BUT I've sorted it out. I've interposed a 14 thou shim washer between the two internal bosses on the castings, it seems to have done the trick.
Cheers, Tony.
peterwpg
PostPosted: Tue Aug 07, 2018 12:12 pm    Post subject: Reply with quote
Well, now that's sorted we can all move on.
Peter L
Kleftiwallah
PostPosted: Tue Aug 07, 2018 6:25 pm    Post subject: Reply with quote
After we have learned something we can tuck away for future reference in the diminishing stock of 'grey cells'!
. Cheers Tony.
Mog
PostPosted: Tue Mar 05, 2019 4:18 am    Post subject: Reply with quote
Not a good idea to use grease , it picks up all the steel file lings and makes good grinding paste ! A little light oil only .
