Spark plugs
Dave1948
PostPosted: Thu Oct 02, 2014 4:28 pm    Post subject: Spark plugs Reply with quote
We would like to find out what is the correct spark plug for a 1948 Ford Prefect.....anybody know?
exbmc
PostPosted: Thu Oct 02, 2014 5:12 pm    Post subject: spark plugs Reply with quote
I have a handbook for a 1953 Anglia. The old Ford sidevalves didn't change much over the years, so the Champion L10 listed in it will most likely be the right ones.
Old Wrench
PostPosted: Thu Oct 02, 2014 5:14 pm    Post subject: Reply with quote
http://www.smallfordspares.co.uk/products/52-12405-a-spark-plug-14mm-l86c
Dave1948
PostPosted: Thu Oct 02, 2014 5:24 pm    Post subject: Reply with quote
Thanks guys...
PostPosted: Thu Oct 02, 2014 5:29 pm    Post subject: Reply with quote
Champion L10, as exbmc says, used to have them in my E83Ws.
Welcome to the forum btw, any chance of a thread about your Anglia?
Rick (OCC Admin)
ka
PostPosted: Fri Oct 03, 2014 6:51 am    Post subject: Reply with quote
I have had so many problems with Champion in both the bike, and the Moggy, I do not give them shelf space. Stick to the NGK for me.
KA
Better three than four.
PostPosted: Fri Oct 03, 2014 7:53 am    Post subject: Reply with quote
Totally agree with that point.
goneps
PostPosted: Fri Oct 03, 2014 9:09 pm    Post subject: Reply with quote
Also agree. The NGK equivalent of L10 is B6HS.
V8 Nutter
PostPosted: Fri Oct 03, 2014 9:11 pm    Post subject: Reply with quote
When I had my old Plymouth I put a set of NGK plugs in it and it would never start when it was hot. I went back to Champions, problem solved!
goneps
PostPosted: Fri Oct 03, 2014 9:16 pm    Post subject: Reply with quote
Sounds as though they were the wrong grade. On the other side of the coin, I recently changed the NGKs in the Morris after well over twenty years, motivated solely by a guilty conscience, not because they were dud.
NONORT
PostPosted: Thu Nov 20, 2014 4:24 pm    Post subject: Reply with quote
I have no connection with them but try the Green Spark Plug Company. I had trouble with a very old Rolls and after contacting them I changed the plugs to a non specified plug recommended by them. No more problems. It would seem that the slower burn rate of unleaded fuel affects the combustion and a different temperature plug was required. Hope this helps.
goneps
PostPosted: Thu Nov 20, 2014 9:26 pm    Post subject: Reply with quote
My understanding is that the flame front of modern fuels travels much faster. The burn is also much hotter and drier than was the case with leaded fuels. These characteristics are probably due to the use of 'aromatic' additives (principally benzine and toluene) to restore the octane rating in the absence of lead.
By the way, this 'orrible stuff is also highly carcinogenic, so keep well away from the fumes when refuelling.
Richard
Hillstart
PostPosted: Sun Apr 22, 2018 4:19 pm    Post subject: Reply with quote
2 nd that unleaded fuel has a faster burn rate
Steve00136
PostPosted: Mon Apr 22, 2019 11:03 pm    Post subject: Reply with quote
Interesting article i found re octane with new and old fuels here at https://mymgbinfo.wordpress.com/2019/04/15/old-vs-new-octane-ratings/
steve
Nottingham
1975 MGB Roadster
www.mymgb.info
1985 CI Sprite 400 caravan
