Joined: 14 Oct 2016 Posts: 1950 Location: East Yorkshire
Posted: Sun Jun 02, 2019 11:13 am Post subject: |
Quote: | and making sure there are no naked flames about.
Or, naked 'old' flames...for that matter... _________________ Dellow Mk2, 1951 built, reg 1952.
DM
Joined: 21 Dec 2008 Posts: 212 Location: North Cornwall
Posted: Sun Jun 02, 2019 11:35 am Post subject: |
Minxy wrote: |
The electric car we are considering can be fast charged in 45 minutes at 50kW. |
Is your house supply capable of supplying 50Kw ?
A normal household single phase supply is usually 16.5Kw. |
Minxy
Joined: 22 Sep 2010 Posts: 272 Location: West Northants
Posted: Sun Jun 02, 2019 12:17 pm Post subject: |
DM wrote: | Minxy wrote: |
Fast chargers are the ones you see in car parks and service stations, at home you charge at about 7kW the idea being you can charge, if necessary, overnight to 100% this will, depending on the car, take you circa 200 mile ( a lot more with a new vehicle) If you are doing a greater mileage you top up at a fast charger if you are in a hurry, or something less aggressive if you have time. _________________ Hillman minx convertible. Lanchester LD 10 |
Miken
Posted: Sun Jun 02, 2019 1:21 pm Post subject: |
47Jag wrote: | I personally can’t see the attraction of converting a classic car to electric. I mean, what our hobby is all about is keeping ancient machines running, against all odds at some times.
Art, I'm sure you are correct and in the majority.
Not looking very hopeful for the survival of old cars, is it.
Mike |
Joined: 23 Nov 2007 Posts: 4755 Location: Swindon, Wilts.
Posted: Sun Jun 02, 2019 4:03 pm Post subject: |
Minxy wrote: | take you circa 200 mile ( a lot more with a new vehicle) |
In daylight, when the weather is such that you don't need wipers, heater or air-con. preferably in a country which doesn't require daylight running lamps.
Try night time, torrential rain/heavy snow/fog etc.
Then how far will it go? _________________ Bristols should always come in pairs.
Minxy
Posted: Sun Jun 02, 2019 5:17 pm Post subject: |
Penman wrote: | Hi
Then how far will it go? |
Er.......a bit less, it’s an electric car! Can’t remember the last time I drove at night with all four seasons being thrown at me though.
Interestingly the countries with the greatest uptake of electric cars are some of the coldest _________________ Hillman minx convertible. Lanchester LD 10 |
Miken
Posted: Sun Jun 02, 2019 6:02 pm Post subject: |
[quote="Minxy"] Penman wrote: | Hi
Interestingly the countries with the greatest uptake of electric cars are some of the coldest[/quote
Don't EV,s have a separate dedicated battery for running the lights, wipers etc? |
Minxy
Posted: Sun Jun 02, 2019 6:11 pm Post subject: |
[quote="Miken"] Minxy wrote: | Penman wrote: | Hi
They do still have a ‘regular’ battery under the bonnet yes to power the 12 volt system but on a long trip in cold adverse weather Penman is quite correct that range would be reduced. _________________ Hillman minx convertible. Lanchester LD 10 |
DM
Minxy
Posted: Sun Jun 02, 2019 7:05 pm Post subject: |
I believe some are better than others it depends on whether they have active battery management ( heaters to warm them when cold, coolant to cool them when hot) or passive management( heat sink from ambient air around the battery). Some can be as high as 30%. This compares with around 12% on an internal combustion engine ( yes it even affects your conventional car) _________________ Hillman minx convertible. Lanchester LD 10 |
Miken
Posted: Sun Jun 02, 2019 8:26 pm Post subject: |
Minxy wrote: |
I believe some are better than others it depends on whether they have active battery management ( heaters to warm them when cold, coolant to cool them when hot) or passive management( heat sink from ambient air around the battery). Some can be as high as 30%. This compares with around 12% on an internal combustion engine ( yes it even affects your conventional car) | How
That's a good point Minxy. I ran a diesel Berlingo for 9 years. On the drive to work in the summer it would do 55mpg. In the winter about 50. It also took about 3 miles to get up to temperature during which I didn't run the heater or it took even longer. |
Rusty
Joined: 10 Feb 2009 Posts: 204 Location: Bunbury, Western Australia
Posted: Mon Jun 03, 2019 2:14 am Post subject: |
47Jag wrote: | I personally can’t see the attraction of converting a classic car to electric. I mean, what our hobby is all about is keeping ancient machines running, against all odds at some times. |
I "shudder" every time I see prince Harry on the TV driving his electric E type, it just misses the point ! Out here we have a chap who does electric conversions on all sorts of vehicles and he drives (or used to, don't know if he still has it) a mid 60s electric Ford Mustang, and I am sorry, but hearing it glide silently past is just "Wrong". |
Minxy
Posted: Mon Jun 03, 2019 8:44 am Post subject: |
Rusty wrote: | 47Jag wrote: | I personally can’t see the attraction of converting a classic car to electric. I mean, what our hobby is all about is keeping ancient machines running, against all odds at some times. |
I agree 100%......but in x amount of years time would you rather see that mustang glide past silently or not see it at all? _________________ Hillman minx convertible. Lanchester LD 10 |
Minxy
Posted: Mon Jun 03, 2019 8:57 am Post subject: |
Back to the OP’s question.
It doesn’t take long on good old google to come up with companies that supply all the basic generic ingredients to convert a vehicle, motors, battery packs, chargers etc etc. There is no separate gearbox with an electric motor just a single speed forward and back ‘cog’ so the output coupling just needs connecting to your prop shaft. Hydrogen could also be employed but would obviously need all the extra hardware that this encompasses on top. From an engineering perspective it would first appear to be relatively strait forward. _________________ Hillman minx convertible. Lanchester LD 10 |
alanb
Posted: Mon Jun 03, 2019 4:40 pm Post subject: |
Whatever type of battery used you can't get out more than you put in, so where is all this electricity going to come from? We don't generate enough for our needs now, we have to buy additional supplies in from France and maybe the French won't sell it to us after brexit _________________ old tourer
Morris 8 two seater |
