Posted: Sun Jun 30, 2019 4:47 pm Post subject: compression test |
Hi all. I have done a compression test on my engine and would welcome your suggestions. Importantly, all the compressions were pretty much the same however there was a 30 PSI difference between first dry - and then wet tests. 105psi dry. 135 wet.
Would this warrant further investigation? |
Posted: Sun Jun 30, 2019 4:56 pm Post subject: |
For me, define Dry and Wet in this case please/ _________________ Bristols should always come in pairs.
Joined: 14 Oct 2016 Posts: 1952 Location: East Yorkshire
Posted: Sun Jun 30, 2019 5:11 pm Post subject: |
Dry...compression tester screwed in, nothing else added to cylinder.....
Wet....small amount of oil added to cylinder before compression tester screwed in, and tested.
A wet test will help to confirm [or otherwise] whether the piston rings are sealing well.
If a compression is 'low', then a subsequent wet test will check the piston ring seal. If the compression rises a significant amount, then rings need sorting [or re-bore, etc?].....If, on a 'low' cylinder, the compression pressure remains much the same, [despite oil being added, on the subsequent wet test]...then that points to valve seal, or head gasket blow.
For Ray, I would say there's a little bit of bore wear, but nowt to worry about for a good few thousand miles yet. _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sun Jun 30, 2019 5:20 pm Post subject: |
Thanks very much Alastair. That was what I was hoping someone would say. There isn't much in the way of smoke - certainly not blue smoke - so I shall leave well alone. |
Posted: Mon Jul 01, 2019 2:56 am Post subject: |
I would agree with Alastair. I would be far more concerned if you found serious differences between the cylinders.
1950 Austin A40 tourer
1999 BMW Z3
Posted: Mon Jul 01, 2019 9:56 am Post subject: |
Keith D wrote: | I would agree with Alastair. I would be far more concerned if you found serious differences between the cylinders.
Keith |
I am thinking it confirms the recorded 25,000 miles. |
