Farmer John
Posted: Thu Jul 25, 2019 9:28 pm Post subject: Oversize undersize |
Hi Ray. Damage to rods and main bearing bores is rectified by grinding mating faces and re-boring to the standard size. More common on conrods as the shells there are more susceptible to spinning, economics are simple, whereas with a block it might be cheaper to replace the block.
John |
V8 Nutter
Posted: Fri Jul 26, 2019 12:03 pm Post subject: |
When I worked at an engine reconditioner's, a re-ground crank had undersized bearings, re-bored cylinders had oversized pistons. Fords sometimes came with blocks that were bored .015 over size for the main bearings, this was simply referred to as backing |
Posted: Fri Jul 26, 2019 1:49 pm Post subject: |
V8 Nutter wrote: | When I worked at an engine reconditioner's, a re-ground crank had undersized bearings, re-bored cylinders had oversized pistons. Fords sometimes came with blocks that were bored .015 over size for the main bearings, this was simply referred to as backing |
Indeed so. Why then are replacement bearings on the market today available in a series of oversizes?
Funny old World isn't it? |
V8 Nutter
Posted: Fri Jul 26, 2019 7:07 pm Post subject: |
I don't very often work on an engine nowadays (retired) when I do its American. I have just ordered bearings .010, .020, whatever no mention of under size or over size not had any problems |
