Head nut torque with solid copper gasket
Goto page Previous  1, 2, 3, 4
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Mechanical
PostPosted: Thu Oct 02, 2008 8:01 pm    Post subject: Reply with quote
Hi Glenn,
As has been said already, the 45lb-ft torque will have been specified for the studs and their anchorage in the block. Clearly there will be some factor of safety in the 45lb-ft figure but I'd be surprised if this took you higher than 60lb-ft. and if the failure mechanism is the block giving way then increasing the torque may be counter-productive as it will start to raise the areas around the studs like a meniscus thus reducing head contact elsewhere.
http://tinyurl.com/ssjaguar
Glenn Crawford
PostPosted: Tue Oct 07, 2008 8:40 am    Post subject: Reply with quote
I get the message! I'll use the original 45 lb.ft torque figure when I refit the head, regardless of whether a copper-asbestos or solid copper gasket is used. At present the head is away for inspection and the solid gasket, if re-used, will be freshly annealed.
By the way, to answer an earlier post, it was not just a plain sheet of copper, it had a reinforced ring around each cylinder seemingly achieved by "crimping" the copper sheet as part of the manufacturing process - Glenn
PostPosted: Tue Oct 07, 2008 9:09 am    Post subject: Reply with quote
I believe what you are describing is a Corrujoint gasket. Quoting from the manufacturer's Service Manual for my car, that also uses such a gasket, "Always use a new cylinder head joint" "Jointing compound should be used sparingly round the water passages only."
My understanding has always been that these gaskets are NOT re-usable.
Jim Walker
PostPosted: Wed Oct 08, 2008 5:07 pm    Post subject: Reply with quote
You are right Peter. I did not consider crimped gaskets when I said copper gaskets could be re-used.
My apologies.
Jim Walker.
Glenn Crawford
PostPosted: Sat Oct 25, 2008 7:07 pm    Post subject: Reply with quote
Having just reassembled the engine I thought I ought to round off this thread nicely by reporting back.
In fact I was more or less an observer, the specialist in Riley Nine engines who has carried out a lot of work on this one in recent years came to my workshop to give it his personal attention. He used a new, freshly annealed solid-copper gasket made by a tuning firm, with a smear of Wellseal assembly compound on both sides. The gasket makers also provided four thin copper rings (just individual strands of 0.2mm car electrical wire soldered into a ring) to place around each bore to give some localised extra "bite".
The surface of the head had been checked and was "true", and the head was torqued to 45 lb.ft, just as if it were a conventional gasket (the head studs are 3/8in).
I've been for a preliminary test run and - fingers crossed - the problem of head gasket seepage seems to have stopped. Is it fixed permanently? Ask me again when the owner has had a chance to cover 500 miles!
Thanks to all for your helpful comments and advice during this mini-saga, and I'm really sorry "Uncle Joe" took umbridge at the fact that I receive payment for fixing other peoples' cars - hopefully he'll come back in from the cold one day.
Glenn Crawford
PostPosted: Thu Nov 06, 2008 11:35 pm    Post subject: Reply with quote
Oh yes, and the owner came and collected the car and drove it home, 135 miles from west Dorset to Teddington in 3¼ hours on the road and without a hitch.
PostPosted: Fri Nov 07, 2008 12:47 am    Post subject: Reply with quote
The copper wire rings are an interesting approach. I'm glad it worked out well. Thanks for the update.
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Mechanical All times are GMT + 1 Hour
Page 4 of 4
Halfords
