Finch661
Joined: 19 Feb 2009 Posts: 162 Location: Edinburgh, Scotland
Posted: Fri Jun 19, 2009 4:51 pm Post subject: wipers not parking |
i have just replaced my park switch in the midget and the wipers still dont park? any ideas on where i can start looking
thanks _________________ 1985 Mini Mayfare (1275)
1976 Mg Midget 1500 |
Posted: Fri Jun 19, 2009 4:53 pm Post subject: |
Hve you checked there is a supply to the park after switching off the teh wiper switch. Sometimes the aux supply is via the ignition or accessory position or a direct fused live _________________ Phil |
Finch661
Posted: Fri Jun 19, 2009 5:04 pm Post subject: |
ah, right, best to probe the switch and plug then to find out.
so when the switch is turned off, the park switch should eb live? _________________ 1985 Mini Mayfare (1275)
Posted: Fri Jun 19, 2009 7:57 pm Post subject: |
One of connections should be - some are live fed via the wiper switch others it is the earth return that is used to complete and break the circuit instead _________________ Phil |
Finch661
Posted: Fri Jun 19, 2009 10:16 pm Post subject: |
fixed! i found that one of the wires leading to the motor had been cut (previous owner must of thought it was a good idea). quick crimp and the wipers now park
many thanks _________________ 1985 Mini Mayfare (1275)
