Posted: Sun Jul 19, 2009 4:48 pm Post subject: Bolts threaded into axle, removal! |
I have the issue that I have some bolts, 4 that are threaded into my axle. I have knocked a socket onto them, but the bolts just disintergrate, and are getting smaller and smaller now.
I am not sure about heating it up, as the axle housing will get warm, also the matter of drilling them out isn't filling me with joy, as they are right on the plain of the centre of the axle.
I thought gentle warming, with a stud extractor, or sillsons to turn them?
Any other thoughts/ideas apriciated!
scott_budds
Posted: Sun Jul 19, 2009 7:00 pm Post subject: |
I have used a few methods of getting very tight bolts undone on my turbo. First I try plusgas which is often fairly good. Im guessing youve tried it? Its a bit like WD40 but for me works more often. If that doesnt work the freeze sprays are my next move. Then for me I try heat. On my turbo I got to this stage and still had some break. If you dont want to use heat I havent try it myself but it is possible to weld a bar on the end of the stud...bit crude but needs must sometimes. On the one I broke I was able to set them up on my machine at work and remove the core and then unwind the remaining part like a spring.
All the best
Buddsy _________________ Im looking for an Elan plus 2 for my next resto project...if you see one think of me please!! |
Posted: Sun Jul 19, 2009 8:11 pm Post subject: |
If there is sufficient head left to grip with Stilsons or Mole Grips then heat head up to cherry red with Oxy Acetylene and allow to cool - never _________________ Rover P2
Posted: Sun Jul 19, 2009 9:05 pm Post subject: |
Thanks for the replies, I will have to have a look, I am not convinced the heads, well what is left of them, won't keep disintergrating, if you saw what they were holding on, you would understand, It is now a big pile of rusty brown power on the floor!
Posted: Sun Jul 19, 2009 9:16 pm Post subject: |
Buddsy, I have done the odd drill out by hand and winding out that thread "like a spring" is so satisfying. It takes a bit of setting up and I am sure you know this but here it is for others, - when one uses a centre punch to create a dimple to start a drill and it is in the right place it is "spot on". _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
Posted: Sun Jul 19, 2009 9:23 pm Post subject: |
When I used to do steam boilers, I used to drill stays, straight down the centre, before shelling them in with an air chissel, and finally punch them out with an air hammer. I used to do 100's in a day, and each old stay was worth £25 scrap!
I might have to go down this route I think with these.
