AUSTIN 301 LORRY/POLARITY CHANGE
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Electrical
holdfast
PostPosted: Wed Dec 30, 2009 11:47 am    Post subject: AUSTIN 301 LORRY/POLARITY CHANGE Reply with quote
Hello
i wish to change the polarity of my 50's lorry. it is positive earth with a dynamo.
i know the starter motor is not polarity sensitive, but i am afeared that something else will short out or explode if i change anything else.
where do i start?
who will hold my hand?
PostPosted: Wed Dec 30, 2009 12:31 pm    Post subject: Reply with quote
Unless its got a radio and possibly a clock - nothing really.
If it has ammeter then leads will need swapping as will coil.
Dynamo may need polarising if does not charge by touching jump lead a couple of times on the D (small) terminal.
Note also that battery terminals are different sizes so may not fit well after just swapping over leads especially if helmet type so will need renewing
Phil
PostPosted: Wed Dec 30, 2009 12:44 pm    Post subject: Reply with quote
We changed lots of vehicles battery polarities to enable the use of solid state two way radios. There are absolutely no problems except with solid state (transistor) components or motors with permanent magnets for the field magnetism (instead of windings). Wound-field motors, like your starter motor will run in the same direction. It is very unlikely that any motors on a 1950s vehicle will have field magnets or solid state electronics.
The procedure is simple. Fit the battery with the polarity reversed and remove the field (small terminal) wire from the dynamo. Connect a jump wire to the +ve battery terminal and hold it on the dynamo field terminal for 5 to 10 seconds. That will reverse the polarity of the residual magnetism in the field poles and the dynamo will charge with positive live.
Job done! But if your regulator makes buzzing noises you did not hold the jump wire on long enough.
There is one exception I know of which is the Daimler DR450 range. There may be others. But if so they will have an alternator WITH POSITIVE EARTH. As long as you have a dynamo there are no problems.
While I was typing this Phil from Nottingham beat me to the posting. He rightly mentions the ignition coil connections. I over looked that, but the small dynamo terminal is the "F".
holdfast
PostPosted: Wed Dec 30, 2009 12:57 pm    Post subject: AUSTIN 301 Reply with quote
Many thanks for advice, i have wanted to fit a radio for years as 30 mph journeys are a bit tedious!
if you hear a BANG over Bromsgrove i havent been paying attention!
First Bedford
PostPosted: Wed Dec 30, 2009 8:31 pm    Post subject: Reply with quote
I have a 52 Bedford, same positive earth. Is there a benefit to changing Polarity?
Pete
PostPosted: Wed Dec 30, 2009 11:08 pm    Post subject: Reply with quote
I would say "no", First Bedford, unless you wish to add modern electronics such as things with transistors or diodes etc.
Just my opinion. I have 3 +ve earth machines and I see no point in changing them from original (authenticity?).
PostPosted: Wed Dec 30, 2009 11:09 pm    Post subject: Reply with quote
The only benefit is that modern electronic equipment can be used without having to make arrangments to ensure it casing polarity is negative earth togther with anything connected to it eg radio aerials.
Phil
First Bedford
PostPosted: Thu Dec 31, 2009 12:46 am    Post subject: Reply with quote
Sorted, it will stay as original.
Pete
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Electrical All times are GMT + 1 Hour
Halfords
