Which contact breaker points?
Bayliss Thomas
PostPosted: Fri Oct 01, 2010 11:30 am    Post subject: Which contact breaker points? Reply with quote
I need to change the contact breaker points fitted to my 1928 Vauxhall 20/60
The distributor is DELCO REMY model 656 KA. This distributor uses an double set of points and I have looked high and low trying to establish which are the correct items to purchase, my request net is also cast far and wide. Can anyone here assist please?
michael1703
PostPosted: Fri Oct 01, 2010 6:26 pm    Post subject: Reply with quote
are they like these?
http://www.holden.co.uk/displayproduct.asp?sg=&pgCode=&sgName=&pgName=&agCode=&agName=&pCode=HK106
Bayliss Thomas
PostPosted: Fri Oct 01, 2010 6:58 pm    Post subject: Reply with quote
They do look very similar but I am not sure if they are the ones I need. I have emailed Holden asking. Thank you for the lead Very Happy
michael1703
PostPosted: Fri Oct 01, 2010 7:06 pm    Post subject: Reply with quote
If they arent the ones and they cant point you to the right ones, I'm pretty sure you can get Lumenition for your car
I know some people prefer points but if you cant get them then at least you have something
traction39
PostPosted: Fri Oct 01, 2010 7:19 pm    Post subject: Reply with quote
Here is a potential supplier State-side. Small piece, low postage costs.
Check the stock list:
www.collectorsautosupply.com/DELCO.PDF
There is an email address at the bottom!
Alistair
Nic Jarman
PostPosted: Sat Oct 02, 2010 9:32 am    Post subject: Reply with quote
I would try A Archer first.
http://www.talbotownersclub.co.uk/Assets/Traders/A_Archer/Talbot%20Spares%20List%20-%20V1.0.pdf
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Bayliss Thomas
PostPosted: Sat Oct 02, 2010 11:48 am    Post subject: Reply with quote
Many thanks for all the leads, I will try A.Archer as first port of call, noted that they deal with vintage Vauxhalls, excellent. Very Happy
