removing wood screws
montreal
PostPosted: Sat Dec 11, 2010 8:32 pm    Post subject: removing wood screws Reply with quote
just spent two days removing 82 year old screws from my praga alfa and wanted to pass on this tip.
it's not mine and i hope i did not read it in this forum!! but somewhere i read that when removing wood screws from old wooden frames the screw can be heated up with a soldering iron and comes out quite easily.
i can certainly recommend this method as after being unsuccessful with other methods i tried this method and it worked extremely well.
in total the doors alone had over eighty screws stuck well in after more than 82 years in place!
apologies if this tip is from the forum, i just read so many tips etc, but it is meant only as a recommendation of the method,
john Very Happy Very Happy
PostPosted: Sat Dec 11, 2010 9:39 pm    Post subject: Reply with quote
Yes it does work well and its good to to pass this simple tip onto others - its an old carpetnters tip apparently but same process but with Oxy A is infallible with steel nuts/bolts which seized
Rover P2
Morris Mini Traveller Mk2
PostPosted: Sat Dec 11, 2010 11:19 pm    Post subject: Reply with quote
Thanks John, I hadn't heard of that one before with wooden frames.
Rick (OCC Admin)
StoneRoad
PostPosted: Sun Dec 12, 2010 2:39 pm    Post subject: Reply with quote
Good tip, I had heard of it before, but usually patience pays off for me. (and a screwdriver of suitable size!)
Take care with brass woodscrews, if the brass has started to lose some of the zinc, they can become very brittle - especially if they have been overtightened or put in at an odd angle! (something boat restorers know only too well.....)
Saluton. mi estas fervojistino, kaj vi?
visit http://www.ipernity.com/doc/312383/album
to see what has been done! Perhaps we can do something for you?
Nic Jarman
PostPosted: Mon Dec 13, 2010 12:03 pm    Post subject: Reply with quote
I wish I had read this before rebuilding the Morris 8.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
