Posted: Sat Jul 09, 2011 5:57 pm Post subject: Austin Devon Restoration
Hallo,
I'm restorating an Austin Devon, Its my first restoration project.
I started with rebuilding the Fuel Pump.
I took it apart, cleaned everything and put all the new parts in and polished it.
I wil not paint it Engine green again.
Very nice, brings back memories of our old Somerset. Are you a member of the Austin Counties Car Club?
No I'm not... but I want to join as soon as possible..
Are you a member?
Well I like somersets, but this Devon just stolen my heart...
And I found it in in my country, Belgium...
Till today I still did'nt found any other Devon in Belgium...
The strange thing is its registerd the first time in '54... and my devon is from '50-'51... So maybe it was standing in a showroom... or...
And I have the opening sunroof!
Posted: Sat Jul 30, 2011 1:33 am Post subject: Fuel Pump
Hi Jonathon,
Just in case you did not know.
When tightening the screws around the pump, the diaphragm must be in its fully stretched condition. Fit the screws very loosely, hold the cam follower arm at the full extent of its stroke, and then tighten the screws.
You might need three hands, it is always a big temptation to put the thing in a vise but no, use you knees or a helper.
Prime it before fitting to the engine, if there was a spacer reuse it.
Good work on the Austin!
John
Posted: Sat Jul 30, 2011 2:50 pm Post subject: Re: Fuel Pump
Farmer John wrote:
Hi Jonathon,
John
Tanks for the tip, I did notice it!
I tested it and it works perfect!
It will take some time befor it will be put back on the car, first I have to rebuild the engine completly!
Thanks for the comment!
Joined: 27 Apr 2005 Posts: 11793 Location: S. Cheshire
Posted: Tue Aug 09, 2011 9:03 pm Post subject:
British heritage cars wrote:
Hallo, Just A question this time..
Is it normal that the number on the cylinder head is different to the engine number at the side of the engine?
Kind regards,
Jonathan
The number on the head is likely to be either a casting number, or a part number, as far as I remember my Devons didn't have the engine number on the block and the head, just on the block.
RJ _________________ Rick (Admin. oldclassiccar.co.uk)
Kind regards,
Jonathan
The number on the head is likely to be either a casting number, or a part number, as far as I remember my Devons didn't have the engine number on the block and the head, just on the block. kind regard, Jonathan
Thanks For the answer Rick!
I just was wondering caus everything is the same BMC engine green, realy everything and the cylinderhead is red? So I'm thinking they replaced..
What do youthink?
Joined: 05 Oct 2008 Posts: 1035 Location: Stoke by Clare, Suffolk
Posted: Thu Aug 11, 2011 12:44 pm Post subject:
Looks a bit sporty to me. Don't worry too much about what is on the outside it's what the inside is like that is more important (and costly). _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Page 1 of 5
