Landrover reverse light
British heritage cars
PostPosted: Sat Sep 03, 2011 6:31 pm    Post subject: Landrover reverse light Reply with quote
Hallo folks!
I want to fix a reverse light on my Series III, some series III do have a hole allready to fix a switch, can anyone tell me if the hole I have is the right one?
Kind regards,
Jonathan
PostPosted: Sat Sep 03, 2011 8:54 pm    Post subject: Reply with quote
just like ours - you need a Mini type switch which has been made since the 930's most Mini's, 1300,Allegros, Metros have them but even the standard S3 brake light switch can be used as used on many cars
Rover P2
Morris Mini Traveller Mk2
welshrover
PostPosted: Sun Sep 04, 2011 2:32 pm    Post subject: Reply with quote
HI ive got the same hole in my gearlever and mines from 1980, but a switch does not work ,as it doesnt have the right selecter behind the hole, the later one has an L shaped bracket that hits the switch to operate the reverse light . Very Happy
