Velo battery
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Classic Motorcycles & Bicycles - General
PostPosted: Thu Sep 08, 2011 6:39 pm    Post subject: Velo battery Reply with quote
Hi all,
I need to buy a battery for the Velo Clubman (500cc). At some point it was converted to 12v, what rating should I be looking for? Obviously there's no electric starter, just the head and tail lamps from memory, so what would be a suitable amp-hour rating to go for??
thanks, R
Bengt Axel
PostPosted: Fri Sep 09, 2011 12:47 pm    Post subject: Reply with quote
I'll ask my dad when I see him at the weekend. His Velo Clubman has now got to the reassembly, rather than dis-assembly stage, so hopefully not long now!.
PostPosted: Sat Sep 10, 2011 10:52 pm    Post subject: Reply with quote
Can't answer this directly Rick. But logically, using only half as many amps to drive things, then only half the amp hours specified for the original at 6 volts.
However bearing in mind that you likely have a more powerful headlamp bulb, used more frequently with modern traffic I would settle for the same capacity as original. Especially if you intend to fit flashers for safety (I won't ride a bike these days without them - young drivers think you are waving at them!)
The modern Gel batteries are much more compact then the old lead/acids so space should not be a problem. In fact a 12volt Gel battery will comfortably fit inside a dummy 6volt case to maintain appearance. With other advantages too.
Anyway, a pint is always better than a half, isn't it? Smile
Jim.
Bengt Axel
PostPosted: Mon Sep 19, 2011 12:40 pm    Post subject: Reply with quote
My dad was not much help to be honest - his view is simply that as long as it generates more than it uses, then you are OK (given that you haven't got a starter motor to worry about).
It is something he will have to tackle himself soon as he plans to convert his to 12v, simply to enable him to fit indicators.
Mrs Axel has a degree in Electronics, so I will ask her.
PostPosted: Mon Sep 19, 2011 11:14 pm    Post subject: Reply with quote
I think I'd just go for the largest (&/or largest amp/hr capacity) that will fit the case. This will give you the most reserve if the dynamo croaks. A deep-cycle design wouldn't hurt, but they get expensive.
Make sure the terminals are in the right places!
Mike
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Classic Motorcycles & Bicycles - General All times are GMT + 1 Hour
Halfords
