Ex-Dennis Poore 1940 Dodge racing car transporter resto
Goto page Previous  1, 2, 3 ... 42, 43, 44 ... 53, 54, 55  Next
Gordon_M
PostPosted: Mon Sep 19, 2011 9:25 am    Post subject: Almost certainly Reply with quote
There are numbers of the 6v Weapon Carrier and so on running round with electronics, no reason why Bess shouldn't.
It's just a low voltage switch really, so the difference between 6 and 12 shouldn't mean much.
Try Dallas Autos, have a look round on the net.
G
PostPosted: Mon Sep 19, 2011 11:40 am    Post subject: Reply with quote
I have a 6v ingition amplifier on the Morris. It uses the original points but no condenser Very Happy . The Morris runs so much better with it. I will PM you with my number.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Sat Sep 24, 2011 10:12 am    Post subject: Re: Ta, Reply with quote
Gordon_M wrote:
Will definitely drop in as and when.
Electronic ignition units are available and should fit, might help?
G
Are they available for 6v?
Hi Rick
Regarding these add on units I agree with Nick, they do make a difference. The way they work is quite simple; on a conventional ignition when the points open the, the field in the coil collapses and the energy released to fire the plug, the "punch" is dependent on 2 factors, firstly how much energy you got in the coil when the points were closed and secondly how quickly the field in the coil collapses.
This type of unit uses a transistor to switch the current on and off to the coil (traditionally what the points do) the points now just switch the transistor.
The benefit of transistor switching is 2 fold; firstly the transistor has less resistance than points, so you will get more energy in to the coil, secondly when the points open the transistor switches off instantly (traditional points don't) promoting a faster field collapse in the coil.
An analogy would be blowing up a balloon and then popping it, the more air you get in and the more instant the deflation; the louder the bang!
A couple of misconnections about electronic ignition, firstly you are not increasing the coil secondary voltage, when the coil field collapses the voltages rises across the spark plug until it is large enough to fire it; this is governed by the gap, the compression, the air fuel mix , and the state of the plug. Secondly the only ignition problem this sort of electronic ignition unit will fix, is a doggy condenser or perhaps doggy points, you do need to get to the root of the problem first.
If you want to stick the jolly green giant on an engine scope, let me know, it takes a lot of the guess work out with this sort of problem.
PostPosted: Sat Sep 24, 2011 1:27 pm    Post subject: Reply with quote
Interesting stuff, thanks. Like you say, I'll suss out what's awry first then review the options. I may take you up on the diags option sometime.
cheers, RJ
PostPosted: Sun Sep 25, 2011 5:36 pm    Post subject: Reply with quote
I covered how points/coil ignition system works at;
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=9820
If you are having trouble with the engine at higher revs then suspect the condenser, even new ones can be s**t.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Gordon_M
PostPosted: Fri Sep 30, 2011 8:34 am    Post subject: Just in from Daryl in Oz .... Reply with quote
Worth keeping this on file, Rick?
Gordon,
As I recall, you were looking for some wheels for the car carrier bus? It may be worth a trip to the breakers to look at wheels from a late 60's early 70's Volvo F86. These use a 20" 10 stud wheel on a 285mm PCD which is the USA standard pattern. Translates to 11.25" PCD. I'm not sure on the Dodge PCD, but Volvo used this standard when trying to break into the USA market, so it might be a lead to follow up on. If they fit, they should also fit the larger trucks and possibly the Burma Dodge.
Cheers,
Daryl in Oz
DD4-35/M601
PostPosted: Fri Oct 21, 2011 1:33 pm    Post subject: Reply with quote
Thanks for the info Gordon, will pop that on file.
Michael Ware (journalist/author/former Beaulieu curator) came by today to get some info for a write-up he's hoping to do on the old girl. Nice to have a chat with him, he met Poore a few times many years ago when Beaulieu were restoring the Poore family's vintage Argyll car.
Gordon_M
PostPosted: Thu Nov 24, 2011 12:52 pm    Post subject: Came up is a discussion on the WW2 Dodge Forum ... Reply with quote
Quote:
..... My electronic ignition is From Jolley Engineering in the UK and that took longer to unpack that it did to fit! ......
Rick please note
PostPosted: Thu Nov 24, 2011 4:01 pm    Post subject: Re: Came up is a discussion on the WW2 Dodge Forum ... Reply with quote
Gordon_M wrote:
Rick please note
interesting - whose quote is that?
Gordon_M
PostPosted: Thu Nov 24, 2011 4:17 pm    Post subject: It's a quote from this thread, Rick Reply with quote
http://forum.ww2dodge.com/viewtopic.php?f=5&t=9129
The thread is about a problem installing Petronix electronic ignition I think.
Gordon
Gordon_M
PostPosted: Sat Nov 26, 2011 1:25 pm    Post subject: Bess in disguise in Holland / Belgium? Reply with quote
http://www.flickr.com/photos/chris1971/6391465539/
Not the same though.
although there are tow hooks, the front metal is 1941-47, and there have been `DODGE signs on the sides of the hood which shows the hood matches the front metal. Different front wheel too?
I'd guess a 1941-47 WK heavy duty 3 ton, possibly ex-military, given the tow hooks.
PostPosted: Sat Nov 26, 2011 7:25 pm    Post subject: Re: Bess in disguise in Holland / Belgium? Reply with quote
If it's Canadian and 3-ton wouldn't it be a D60L? If it's American I'd have guessed at a 2-ton truck looking at it, is the front axle wide enough for a 3t US truck?
Gordon_M
PostPosted: Sun Nov 27, 2011 8:56 am    Post subject: Re: Bess in disguise in Holland / Belgium? Reply with quote
Absolutely NOT A D60 is the light duty 3 ton T110L, either long or short wheelbase, with the 236 cu in engine.
That's a full sized heavy duty 3 ton like Bess, I assume with the 331, although it does look to have been supplied to / via Canada and have Canadian / British / Commonwealth pattern wheels on the front. A further post suggests 1944 date and Canadian Army use.
Note in particular that is does seem to have a windscreen cowl on it, like Bess, and not a cut-down or cobbled up cab.
PostPosted: Thu Dec 01, 2011 9:09 pm    Post subject: Reply with quote
Interesting stuff. I didn't realise that the Canadian 3t trucks had the 331 but I've not researched them in great depth Smile
"Uncle Alec" tipped me off that the old girl gets a mention in this month's Classic Motor Monthly paper. As a result of the article two people have been in touch, one contacted me via HMG paints and remembers visiting Poore's pad in London (he used to fix their electric garage door!), while another got in touch whose father used to run this model of Dodge (flatbed versions) in the 50s, and has a cylinder head in his shed going spare.
Gordon_M
PostPosted: Fri Dec 02, 2011 9:24 am    Post subject: Good Reply with quote
I remember the head on Bess had a repair on it anyway, so a spare would be useful - no like there would be a big market for a spare head, even worldwide.
Gordon
Page 43 of 55
