Posted: Wed Feb 15, 2012 9:34 pm Post subject: How do I wire a generator warning light?
I am fitting a fuse box and doing some rewiring on my 1926 Austin 12. Although the car is fitted with an ammeter, I thought I would also fit a generator warning light on the dashboard. This should hopefully come on when the ignition is switched on and go out when (if...?) the generator begins to charge.
The car has been fitted with a Lucas voltage control box and this has a warning light terminal - so ok, there is one connection to the lamp. My question is, where does the other side of the warning lamp go?
I am assuming it must take a live feed from the ignition switch but I can't quite get my head around this set up.
Anyone care to confirm / explain please?
Thanks, _________________ Alan
1957 Ford 103E Popular
1926 Austin 12/4 Clifton Tourer
1966 Humber Sceptre MkII
Joined: 27 Dec 2008 Posts: 1116 Location: Chesterfield
Posted: Wed Feb 15, 2012 11:34 pm Post subject:
47Jag wrote:
Alan,
Wire one side of you warning light to the ignition switch and the other to the 'D' terminal of the regulator.
Art
Surely that should be the F terminal? Otherwise it will glow with reverse voltage when the dynamo charges.
Joined: 26 Jun 2008 Posts: 645 Location: Bothwell, Scotland
Posted: Wed Feb 15, 2012 11:40 pm Post subject:
No! The lamp is lit by the potential differences (voltage) between the battery and the dynamo (D terminal). The cut-out closes and both sides of the lamps are then at the same voltage and it's out.
