Posted: Sun Feb 05, 2012 11:22 am Post subject: Brake reservoir
Brake reservoir
I’ve got an old brake ‘tin can’ type fluid reservoir on my ‘33 Singer. Externally it is great with the original transfers still visible (ie. I don’t wish to replace it!), internally however there is rust and gunk.
Is there a tank seal I could use to make it usable? - I intend to use silicone brake fluid in the system.
What type of mc have you got - i've just fitted a universal type on a landrover mc. I wouldn't use silicon brake fluid - i'll get out a publication for you if you like. Main negative is if you want to revert to normal fluid it is a devil to get out of the system.
Posted: Sun Mar 04, 2012 10:42 am Post subject: Brake Fluid Tank
Thanks for the reply!
......I took a long hard look at the original tank and concluded that even after extensive internal cleaning it would still be dodgy (for brakes anyway!)
Found a site that did a nice new MK1 Landie fluid tank of similar style -£33
Would be interested in the info on the fluid still...... seems the way to go.
Joined: 26 Nov 2007 Posts: 175 Location: North Warwickshire
Posted: Wed Mar 14, 2012 10:11 pm Post subject: Re: Brake Fluid Tank
Regards!
Have you bought the Land Rover item? If not yet, and you'd still like to keep yours looking original, stickers etc, could you source a reservoir ever so slightly smaller than yours and insert new one inside existing? Maybe make a cut-out in the base of original to permit access to connection on new one?
