Joined: 19 Mar 2008 Posts: 297 Location: Kelvin Valley,Scotland
Posted: Thu Feb 09, 2012 2:59 pm Post subject:
MVPeters wrote:
This is an odd one:
Check the V angle carefully on the belt - if it's not correct for the pulleys it 'snaps' out as it turns. The noise is horrific. Spray it with water & see if it changes.
Should be an 'A' size belt,approx 13mm across the flat side - may have been fitted with a 'B' size belt(in an emergency?) which is approx 17mm across the flat side so obviously the 'V' doesn't fit the 'A' groove properly,cheers,JD. _________________ Use 'em or lose 'em.
1960 Ford Zephyr.
1968 Triumph 2000.
Posted: Mon Mar 12, 2012 6:48 pm Post subject: 1914 Saxon
mikeC wrote:
I am slowly working may way through re-commissioning (or should that be comissioning, since I don't think it has been run since restoration in the 1980s) of my newly imported Saxon. Much of the work so far has been finding/modifying things to make it UK-legal (lights, horn, registration plates, etc) and I am now going through the mechanics prior to MOTing so that I can get it registered. I fired it up for the first time last week, which revealed a flaw in the fuel system, so I have now reworked that, and it looks like I may now have to adjust (hopefully) or rebuild the clutch, and then we are just about there...
Meanwhile, I am also doing some building work on the garage itself, which explains the tip in the background
[quote]
Super looking car. may I ask if you have it running on the Atwater Kent distributor or a modern one as I see you have a coil fitted. Mine is still on the original and on 6 volt. The restored condition of your car has made me rethink that I should possibly restore mine which I had been loath to do as I had been rather disposed to leave it original. John
Joined: 27 Apr 2005 Posts: 11732 Location: S. Cheshire
Posted: Mon Mar 12, 2012 7:09 pm Post subject: Re: 1914 Saxon
[quote="earlyamerican"]
This is an odd one:
Top marks chaps, it was the belt! Fitted an original spec one and the noise stopped straight away. Cheers _________________ 1952 Austin A90 Atlantic
1958 Austin A35
1959 Austin A35
1958 Austin A55 Cambridge MK1
Posted: Tue Mar 13, 2012 11:53 pm Post subject: Re: 1914 Saxon
[quote="Rick"]
Do you have any shots of your car to add in? it'd be neat to see some if possible.
I have tried to follow the path to put pics. on Rick but it just isn't working for me. I could have rebuilt about a dozen engines in the time I have spent trying. Feeling less frustrated now having spent the afternoon shaping some Model T wings. John
Posted: Mon Mar 19, 2012 10:19 pm Post subject: Re: 1914 Saxon
Super looking car. may I ask if you have it running on the Atwater Kent distributor or a modern one as I see you have a coil fitted. Mine is still on the original and on 6 volt. The restored condition of your car has made me rethink that I should possibly restore mine which I had been loath to do as I had been rather disposed to leave it original. John[/b]
Hi John,
I have only just seen your post - it is still on the original Atwater Kent distributor, and it runs fine with the modern coil, although I am hoping to re-instate the AK coil box eventually. I think if your car is still presentable, then leave well alone - you can restore it sometime in the futue, but you can never regain an original...
Posted: Tue Mar 20, 2012 7:24 pm Post subject: 1914 Saxon
I had thought to keep it original but cannot help thinking how nice your car looks. Mine has remained untouched and laid up since damage while racing in 1917 I have all paperwork since then as it passed through 3 branches of the same family. Now with some parts gently repaired new bearings and tyres she is back on the road.
Posted: Tue Mar 20, 2012 7:34 pm Post subject: Re: 1914 Saxon
That's stunning as it is - it'd be worth starting a new thread in the Your Cars.. section of the forum, I really like that
R _________________ Rick (Admin. oldclassiccar.co.uk)
Earlyamerican, keep the car as it is. I will always remember my Morgan 3 -wheeler as a vintage car. I enjoyed driving as it was, not a 2-pack resprayed thing, it never was.
Posted: Thu Mar 22, 2012 10:03 am Post subject:
The car has real style and it would be nice to keep it as it is. _________________ If you tie a piece of buttered toast to a cat's back, then drop it off a high building. It will hover just above the ground rotating slowly.
Page 3 of 3
