Austin 1100 Auto box changing too early
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Mechanical
Welshie
PostPosted: Fri May 18, 2012 12:38 pm    Post subject: Austin 1100 Auto box changing too early Reply with quote
My dad has just bought a 1970 Austin 1100 auto to run around in (pictures later). Al is well but we've noticed that the automatic gearbox changes up way to early (before the revs have picked up enough) so when its cold you have the change the gears manually as the engine just bogs down. No wierd noises, it drives fine and apprently the previous owner changed the oil (I know its combined angine and gearbox lubrication on these). Any ideas?
1971 MGB GT (V8 project)
1964 Ford Anglia 105E 1500 GT
1963 Hillman Imp Deluxe
PostPosted: Fri May 18, 2012 1:52 pm    Post subject: Reply with quote
I'll ask dad when I next see him (he's just left), his Vanden Plas 1300 is auto too. It changes gear at low speeds too - correctly - but doesn't bog down like your's seems to be doing.
PostPosted: Fri May 18, 2012 3:03 pm    Post subject: Reply with quote
It's 40 odd years since I've seen one but isn't there a cable from the carb. linkage down to the gearbox? If so it might need adjustment.
Art
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Mechanical All times are GMT + 1 Hour
Halfords
