Leaking float chamber on no2 carb
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Classic & Vintage Cars - General
gillberry
PostPosted: Sat May 26, 2012 6:54 pm    Post subject: Leaking float chamber on no2 carb Reply with quote
Hi all as in the title is our problem . Our floats are the moulded fixed type so I'm assuming I would need to shim the needle valve to help rduce float height . Any suggestions would be much appreciated .
PostPosted: Sat May 26, 2012 7:55 pm    Post subject: Reply with quote
Is it not a sticking needle valve? I had that with the green 122S on a couple of occasions.
gillberry
PostPosted: Sat May 26, 2012 8:11 pm    Post subject: Reply with quote
Thanks for the reply but no new valve inserted as had repair kit delivered today . The thought at the moment is that as I have non adjustable floats I need to get some brass shims .
Mog
PostPosted: Sun May 27, 2012 4:49 am    Post subject: Reply with quote
I did have a brass float on an Aussie Ford that decided to spring a leak on a busy 6 lane highway. I managed to get it off the road and went back for it next day. Of course I got a few extra gray hairs trying to work out the problem. As the float was sunk in the bowl, the solution was to drive it "hard " and use as much fuel as possible. Lucky I was not far from home, about 5 klms. Another problem with that car was it would stop running when sitting at traffic lights etc. I found the solution was hit the carby. with a hammer or piece of heavy steel ! The problem was the brass non return valve was worn, when replaced, I had no more problems. Always look at the needle in needle valves carefully, if the get worn , they can have a step in them.
Kelsham
PostPosted: Mon May 28, 2012 7:24 am    Post subject: float Reply with quote
Although you say the mechanism is non adjustable, you do realise that some can be adjusted by bending the arm?
I have had a problem in the past, where the arm met the needle valve at an unsuitable angle, forcing the needle valve sideways causing enough friction to make it bind.
Regards Kels.
gillberry
PostPosted: Mon May 28, 2012 7:29 pm    Post subject: Re: float Reply with quote
Regards Kels.
Thanks for your post but our plastic float is a one peice unit that has no adjustment .
Thanks to all who replied problem now sorted . Managed to adjust the needle enough to acheive the required clearance .
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Classic & Vintage Cars - General All times are GMT + 1 Hour
Halfords
