zagatoman
Joined: 31 Aug 2010 Posts: 55 Location: Sutton, Surrey
Posted: Sat Apr 16, 2011 3:29 pm Post subject: Vauxhall Victor FB VX490 carburettor problem HELP! |
Hi, wonder if anyone can help.
Trying to get my Vauxhall FB Victor VX490 to run right.
The VX has got twin carburettors and have had it running but if a just let it tick over the revs increase and decrease without me touching it. What could be the problem?
The carburettors are balanced and the slow running screws are adjusted.
Paul |
Posted: Sat Apr 16, 2011 4:32 pm Post subject: |
A wandering tickover is often the result of an induction air-leak. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
poodge
Posted: Sun Apr 17, 2011 7:36 am Post subject: |
I'm not sure if your carb has the same set-up,but I remember having a similar problem with a PB Vauxhall in the 70's.Viva's used to have the same problem.It was caused by the heat from the exhaust manifold actually burning a hole through into the inlet manifold.I fixed it by inserting a plate between the two,but a better fix would be to have it brazed.
hope this helps. |
Churchill Johnson
Posted: Sun Apr 17, 2011 10:03 pm Post subject: |
If i remember from my day's working on these they have twin Stromberg's have you tried enriching the mixture to see if this make's any difference, or as has been suggested it may be an air leak this can normally be found by using an oil can putting the oil along the inlet manifold to head joint and see if it get's sucked in will show up as blue smoke as well or around the carb to inlet manifold joint's if none of these work the carb's may need new diaphram's another thing, will it run ok if you increase the rev's slightly,are you trying to get it to tickover to slow, these 4/90's do not tickover like like the normal cooking engine. |
JohnDale
Posted: Sat Apr 30, 2011 1:31 pm Post subject: |
I think Churchill has it correct - check the diaphragms, cheers,JohnDale. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
