Armstrong lever shock absorbers
nqtraderman
PostPosted: Sun Jul 03, 2011 10:51 pm    Post subject: Armstrong lever shock absorbers Reply with quote
At 57 years old I suspect mine are in need of a service. Does anyone know a good place that services them, preferably in NW ?
Or is it a DIY job - assuming its not just topping up with hydraulic oil
Owner of a 1953 Sunbeam Alpine
PostPosted: Mon Jul 04, 2011 7:30 pm    Post subject: Reply with quote
You don't mention the vehicle, but only last week I bought an exchange (re-conditioned) Triumph Vitesse lever shock absorber from Canley Classics for £25.40. Which I thought very reasonable.
Of course they specialise in Triumph parts, but they might be able to get yours done or point you in the right direction if it is not a Triumph.
Jim.
PostPosted: Tue Jul 05, 2011 12:55 pm    Post subject: Reply with quote
Try Stevson Motors - Telephone: 0121 471 3312
I have no connection with them!!
Paul
PostPosted: Tue Jul 05, 2011 1:54 pm    Post subject: Reply with quote
Apparently it's not a major job to refurbish the lever arm shock absorbers oneself
ROVER
One of Britain's Fine Cars
Jason
PostPosted: Wed Jul 06, 2011 8:24 am    Post subject: Reply with quote
I refurbished the Alvis ones myself, I found a guide on the internet and I used motorcycle fork oil as recomended by a motor vehicle maintenance tutor (when I was at college)
hope this helps
"people with money buy a Rolls Royce, people with taste buy an Alvis".
nqtraderman
PostPosted: Wed Jul 06, 2011 9:18 am    Post subject: Reply with quote
hope this helps
That sounds interesting, I might do mine over the winter period. They are 57 years old and the bounce is different on all 4 corners but they will do for now. Any chance of a link to / copy of that guide ?
thanks
Jason
PostPosted: Wed Jul 06, 2011 9:50 am    Post subject: Reply with quote
I can't remember the website I used but heres a link to some good pictures and details of which screws do which job.....
http://www.singercars.com/4ax/armstrong.html
hope that helps a bit.
p.s...take note of the sentence at the bottom of the page, they may just need fresh oil
nqtraderman
PostPosted: Wed Jul 06, 2011 10:25 am    Post subject: Reply with quote
Thanks for the link. There's a reasonable chance that fresh oil will be all they need, there are no leaks that I can see and although I could top up the oil in-situ it may be easier to remove them and replace the oil when they are on the bench, then I can move the arm up/down easier to get the air out.
There is a lot of debate on forums which oil to use in the shocks, but if you're happy with the motorbike fork oil you put in then I'll go with that too.
cheers
Jason
PostPosted: Wed Jul 06, 2011 10:43 am    Post subject: Reply with quote
there are different grades of fork oil though, give me 10 minutes I'll pop up to my shed and take a look which I used.
Jason
PostPosted: Wed Jul 06, 2011 10:49 am    Post subject: Reply with quote
just been up to shed to check, I used....
Silkolene SAE 20 heavy grade fork oil in 500ml tubs
my 4 shockers took just over 500ml so your best of getting 2.
if I remember correctly its about £10 per 500ml
nqtraderman
PostPosted: Wed Jul 06, 2011 12:23 pm    Post subject: Reply with quote
Thanks Jason, very helpful, I'll make a note of that oil and the qty needed.
cheers
Bill
