Sprite oil filter
PostPosted: Thu Dec 01, 2011 12:21 pm    Post subject: Sprite oil filter Reply with quote
I have a mk4 sprite with the 1275 engine. That time has come when I have to change the oil and filter and it's a nightmare changing the cartridge and avoiding leaks.
Someone told me a later type body could be fitted that takes the screw-on filter? Has any one done this?
PostPosted: Thu Dec 08, 2011 10:25 pm    Post subject: Reply with quote
I have, on my Triumph Vittesse engine in my Gentry and also on a boat I had, powered by a 1.5 BMC Diesel.
An aluminium casting bolted directly in place of the of the original canister with a shorter (supplied) bolt and the spin off canister fitted the other end of the casting.
Kits were readily available a few years ago, but I imagine demand has fallen, so they may not now be available except as old stock.
Perhaps Europa Cars of Burton on Trent may help?
There is another firm which does a HUGE range of clever mod. bits for custom and kit car builders etc., but I cannot for the life of me remember the name.
Jim.
Car Builder Solutions is the firm I had in mind. I just found it on the 'net.
I have not checked out their list because it is huge! That's up to you! Here's the link.
http://www.cbsonline.co.uk/
PostPosted: Thu Dec 08, 2011 10:41 pm    Post subject: Reply with quote
Thanks Jim. Will try them.
exbmc
PostPosted: Sun Dec 11, 2011 5:20 pm    Post subject: Sprite oil filter Reply with quote
It's a long long time since i worked on a Sprite, so i may be wrong. If you have a filter head on the front / right of the engine, with a pendant canister and paper element, i think you can fit a filter head off a later "A" series. This would have to be a front wheel drive job, mini or allegro. You could then fit a spin on filter. The head is only held on by two studs and nuts and has an oil pipe attached.
PostPosted: Sun Dec 11, 2011 5:50 pm    Post subject: Re: Sprite oil filter Reply with quote
Thanks for that. Just a matter of tracking down an old 'A' series. They used to be lying about everywhere but not so easy to find these days.
My next job on the list.
exbmc
PostPosted: Tue Dec 20, 2011 9:34 pm    Post subject: oil filter Reply with quote
I know it doesn't help you pigtin, but a friend of mine who has been trying to restore a rapidly crumbling Midget, has today bought a better bodyshell off e-bay. In the deal was a 1098cc engine, and this has had the later filter head fitted, as i mentioned before. It will make filter changes easier, when he eventually gets the car mobile.
kismet
PostPosted: Tue Jan 03, 2012 11:25 am    Post subject: Reply with quote
DSN Classics will have them in stock if you're not yet sorted:
http://www.dsnclassics.co.uk/acatalog/
PostPosted: Tue Jan 03, 2012 10:45 pm    Post subject: Reply with quote
Many thanks kismet.
