1937 Morris 8 - dry seized engine.
welder
PostPosted: Thu Feb 23, 2012 9:43 pm    Post subject: Reply with quote
Kelsham wrote:
Try fresh fuel in the carb, I have had problems in the past. Petrol was only about a year old. Would run when started on new fuel and continue to run on old petrol when warm.
Regards Kels.
Kels, thanks for that. I have drained the fuel system of what was once petrol and put a gallon of what is definately petrol into the tank. Nowt!
I've convinced myself that I've got the sparks arriving at the wrong time in the Otto cycle so this weekend I shall mostly be sorting that out, aided and abetted by our 19 month old grandaughter who just loves being in the garage with Grandad. She sits in the drivers seat shouting instructions in a form of language that will, eventually, become English.
She's possibly telling me to get on with things as her Dad wants to go to his wedding in the car. No pressure, then.............
Ian
PostPosted: Thu Feb 23, 2012 10:19 pm    Post subject: Reply with quote
Since you used CocaCola to free off the engine, maybe you should Put Some Tizer In Your Tank!
Mike
JC T ONE
PostPosted: Thu Feb 23, 2012 11:31 pm    Post subject: Reply with quote
GAV105E wrote:
HA !!! i promise you this will work. If it doesnt i will personally come and buy you and all your mates beers all night down your pub !!!!!
I pulled a anglia 105e out of a garage last week which had been sat there for 20 odd years, the engine was solid, i had a huge socket and bar on the crank pulley and was solid.
i took the plugs out, poured a fair amount of COCA-COLA down each bore , ate a sandwich put a blue point ratchet spanner on it and it was as free as a bird !!
Also last year i did exactley the same with a Austin cambridge estate, been sat 32 years and was extremley solid, coke down the bores and we had it running in no time !!!
Hi I just bought an old Mini engine, that sat in a garden for 30 years (without manifolds) and its stuck, I took off he valve cover, and removed the rockers, to find that 4 valves also are stuck Rolling Eyes the gearbox is also rusted solid Crying or Very sad do you think Coca Cola can help here also ?
J C
welder
PostPosted: Fri Feb 24, 2012 12:23 am    Post subject: Reply with quote
I see what you did there. Smile
I well remember the old Esso ad campaign "Put a Tiger in your tank", and all the furry tigers tails, rear screen stickers and the like that went with it.
I'll stick with premium unleaded, thanks.
Ian
welder
PostPosted: Fri Feb 24, 2012 12:31 am    Post subject: Reply with quote
J C
JC, it can't harm to try it. Buy a large bottle and use half of it.
If it does'nt work you can console yourself by adding a nice vodka to the remainder.
Good luck, either way Confused
Ian
JC T ONE
PostPosted: Fri Feb 24, 2012 1:41 am    Post subject: Reply with quote
Ian
Hi Ian, thanks for the advice, I will do that, but I think it will take me a lot more than half a bottle of Coke & vodka,
to console myself if it doesnt Crying or Very sad
Then I might do plan B & put it into a big jar full of Diesel, and leave it for a couple of years Wink
Jens Christian
bob2
PostPosted: Fri Feb 24, 2012 9:23 am    Post subject: Reply with quote
Is this a special engine of some sort JC?
Surely not a simple 998 or 1275 which are still plentiful if you're going to all that trouble!!
JC T ONE
PostPosted: Fri Feb 24, 2012 6:24 pm    Post subject: Reply with quote
Hi N,
Was waiting for someone to ask that question Wink and a big YES Cool
Its one of those engines with the BIG bore, and tappet covers, that can be removed, from the block.
It has too many studs&bolts to hold the head, no vacuum on the destributer, and a "FAT" flange where you bolt it to the gearbox .
Ohh and the gearbox has driveshaft couplings, that share first name with one part, of a VERY famues American comedy couple Wink
Jens Christian
welder
PostPosted: Sun Feb 26, 2012 2:01 am    Post subject: Reply with quote
Hi N,
Jens Christian
Laurel and Hardy? Hardy-Spicer? What, for goodness sake? I need to sleep nights!
The remnants of the once mighty Hardy Spicer is about 3 miles from where I sit, a great friend of mine carries out repairs/rebuilds/maintenance related to their heat treatment process equipment and may, possibly, have access to otherwise unobtainable stuff.
Anything you need?
Ian
JC T ONE
PostPosted: Sun Feb 26, 2012 11:20 pm    Post subject: Reply with quote
Anything you need?
Ian
Hi Ian, you are correct Cool its has Hardy Spicer driveshaft axle/couplings.
Better get you to bed then Wink
Its a genuine thick flange S, with removable tappet chests on the back.
11 stud genuine S head, S destributor, S rocker gear, etc
The original 1275 alloy plate, is still attached, on the back of the engine Cool
I am missing one side, for the axle ? if you can help ?? can I post a picture.
Jens Christian
Kelsham
PostPosted: Mon Feb 27, 2012 9:44 am    Post subject: Reply with quote
Bear in mind that Cola is a mild acid. If you intend to use it it would be wise to consider how you will remove it afterwards.
Regards Kels.
bob2
PostPosted: Mon Feb 27, 2012 10:16 am    Post subject: Reply with quote
nice find JC, you could always start a new thread about it!!
welder
PostPosted: Mon Feb 27, 2012 8:36 pm    Post subject: Reply with quote
Anything you need?
Ian
Jens Christian
Jens, put up a photo of the item you have and I'll pass it to my pal Frank who I mentioned. He's something of a petrol head too so would be pleased to help if he can.
Ian
JC T ONE
PostPosted: Tue Feb 28, 2012 5:14 am    Post subject: Reply with quote
Thanks N, but I didnt "find" it, a friend did, but it was TOO bad for him, so he passed it on to me.
Can make some pictures, and post.
JC T ONE
PostPosted: Tue Feb 28, 2012 5:17 am    Post subject: Reply with quote
Ian
Hi Ian, and thanks, I will make a picture of the axle part I am missing.
The diff & output flanges are all there, its only one axle part missing.
Jens Christian
Page 4 of 10
Halfords
