Brake reservoir
whiteshadow
PostPosted: Sun Feb 05, 2012 11:22 am    Post subject: Brake reservoir Reply with quote
Brake reservoir
I’ve got an old brake ‘tin can’ type fluid reservoir on my ‘33 Singer. Externally it is great with the original transfers still visible (ie. I don’t wish to replace it!), internally however there is rust and gunk.
Is there a tank seal I could use to make it usable? - I intend to use silicone brake fluid in the system.
Thanks in anticipation!
jessejazza
PostPosted: Sat Mar 03, 2012 11:57 pm    Post subject: Reply with quote
What type of mc have you got - i've just fitted a universal type on a landrover mc. I wouldn't use silicon brake fluid - i'll get out a publication for you if you like. Main negative is if you want to revert to normal fluid it is a devil to get out of the system.
whiteshadow
PostPosted: Sun Mar 04, 2012 10:42 am    Post subject: Brake Fluid Tank Reply with quote
Thanks for the reply!
......I took a long hard look at the original tank and concluded that even after extensive internal cleaning it would still be dodgy (for brakes anyway!)
Found a site that did a nice new MK1 Landie fluid tank of similar style -£33
Would be interested in the info on the fluid still...... seems the way to go.
Regards!
welder
PostPosted: Wed Mar 14, 2012 10:11 pm    Post subject: Re: Brake Fluid Tank Reply with quote
Regards!
Have you bought the Land Rover item? If not yet, and you'd still like to keep yours looking original, stickers etc, could you source a reservoir ever so slightly smaller than yours and insert new one inside existing? Maybe make a cut-out in the base of original to permit access to connection on new one?
Just a thought.
Ian
