Condition of NOS headgaskets
PostPosted: Mon Sep 10, 2012 6:15 pm    Post subject: Condition of NOS headgaskets Reply with quote
I have a couple of NOS headgaskets in the loft, they're not perfect factory fresh examples and I was wondering if they were fit to use. Sorry if the photos aren't much cop, but hopefully you'll get the idea.
First problem is verdigris on the copper, thus:
Is it OK just to clean this off with a fine abrasive?
Next problem is where the gaskets aren't straight, thus:
I reckon a wavy one like this will flatten out OK when the head is fitted, but then I have one with some small creases, thus:
Would these be OK or are they only fit for the bin? I can still get new headgaskets, but other people may be equally unsure about their parts collection and not have that option!
PostPosted: Mon Sep 10, 2012 6:44 pm    Post subject: Reply with quote
The corrosion on the copper I'd clean off and it should be ok so long as the surfaces are undamaged. I don't think I'd trust a gasket with a crease in it mind, same for delamination, unless it was an uber-rare gasket and I had no other choice.
PostPosted: Mon Sep 10, 2012 7:27 pm    Post subject: Reply with quote
With the corrosion woudn't even a light abrasive take off some material?
Why not use brown sauce painted on to it? It has a similar efffect on copper coins as leaving them over night in cola or milk.
PostPosted: Mon Sep 10, 2012 9:37 pm    Post subject: Reply with quote
Pretty much my own thoughts, but I'll have to try the brown sauce!
Kelsham
PostPosted: Tue Sep 11, 2012 5:28 pm    Post subject: Reply with quote
Some years ago I read that it was possible to immerse old asbestos gaskets in water to re juvenate them.
I have never tried it myself but it sounds like a feasible action.
If the copper is only slightly creased you will likely be OK.
Regards Kels.
PostPosted: Tue Sep 11, 2012 5:38 pm    Post subject: Reply with quote
Regards Kels.
Interesting. Is the idea that the water swells the asbestos and that straightens them out? I think I'll try that, just for the hell of it - we're not on a meter so it'll cost nowt to see what happens Smile
PostPosted: Tue Sep 18, 2012 1:29 pm    Post subject: Reply with quote
I have heard of the water immersion trick being done with cork gaskets - especially as they shrink when they dry out. Not heard of it for asbestos.
PostPosted: Tue Sep 18, 2012 10:19 pm    Post subject: Reply with quote
I wouldn't soak these asbestos-lined head gaskets for too long -- 15 mins in hot soapy water should be enough.
I'd be concerned about the glue or whatever that holds the asbestos powder together may break down. A gentle scrub with a nylon pot scourer will get rid of most of the corrosion.
For dried-up cork, I use WD40 or ATF - they'll still be delicate, but much more supple.
2002 MINI Cooper 'S'
