Towbar Electrics Pos Earth
Riley472
PostPosted: Tue Apr 09, 2013 7:26 pm    Post subject: Towbar Electrics Pos Earth Reply with quote
Sorry if it's a silly question but do I just wire up the towbar as detailed in normal towbar electric diagrams or do you have to change wires around, I am fitting to my Austin Countryman with +Pos earth? Also what about the warning buzzer is this wired the same as a -Neg earth wiring diagram.
Thanks
PostPosted: Tue Apr 09, 2013 10:15 pm    Post subject: Reply with quote
Absolutely - as to a warning buzzer it should be dual polarity but if its got any electronics in it it will not work on +ve earth
Rover P2
Morris Mini Traveller Mk2
Riley472
PostPosted: Sat Apr 13, 2013 5:17 am    Post subject: Towbar Electrics Pos Earth Reply with quote
Thanks Phil Very Happy
Riley472
PostPosted: Mon Apr 15, 2013 3:52 pm    Post subject: Towbar Electrics Pos Earth Reply with quote
Having some right problems sourcing a warning buzzer, suppliers of buzzers I have spoken to have said they will only work on -neg earth.
Does anyone know where I can get a buzzer that will work on +pos earth.
Thanks
PostPosted: Mon Apr 15, 2013 4:49 pm    Post subject: Reply with quote
Use the normal indicator warning light instead.
So long as it has a trailer suitable flasher unit, the indicator warning will flash faster when any indicator bulb fails, in the same way that it will on any car when driven solo.
