petelang
Posted: Mon May 27, 2013 2:30 pm Post subject: Block needing recovery |
Hi Guys.
I hope I can get some helpful recommends on here. I am looking for an engineering works who know their onions to reclaim a very rare 1933 Armstrong Siddeley 15 hp Block. It has been left in the weather as a built up engine for a few years and sadly filled up with water. Fortunately the crank was well oiled and is in astonishing good order and as it had all new bearings in it has excluded water penetration. The main problem is terrible pitting on the bores and as it has +40 pistons in it is probably past cleaning up & needing sleeving. Regrettably the camshaft cannot be budged and is siezed in the bearings.
Does anyone here know any East Midlands or Midlands trustworthy suppliers? I have contacted a couple but they ran away when I explained what it was from, seems they only want to do more modern stuff.
Peter |
Posted: Mon May 27, 2013 4:01 pm Post subject: |
Hi Peter,
You could try:
Contact: Ian Burlingham
Address: 29 Church Street
Dunnington
York
YO19 5PP
United Kingdom
Telephone: 01904 780000
Mobile:
Fax: 01904 481942
Email: ian@johnsonsengineers.com
Posted: Mon May 27, 2013 5:56 pm Post subject: |
Hi Peter
You could try Dave Rushton Engines in Stoke. They have re-sleeved a 1939 Morris 8 block for me as well as other engineering work. They can line bore if the camshaft needs needs bearings (I'm assuming the cam originally ran straight in the block?). They don't disassemble stuff, just do the machining.
gragol
Posted: Mon May 27, 2013 7:32 pm Post subject: block recovery |
you could try the headshop in Warrington |
V8 Nutter
Posted: Mon May 27, 2013 9:08 pm Post subject: |
Try MJA engineering in Bromsgrove Martin (the owner) can certainly supply and fit a set of liners |
petelang
Posted: Tue May 28, 2013 12:10 am Post subject: |
Great leads there guys. I'll ring round next week.
Thanks
Peter |
