Frogeye Sprite Speedometer Cable Routing
IanD
PostPosted: Tue Sep 03, 2013 11:03 am    Post subject: Frogeye Sprite Speedometer Cable Routing Reply with quote
I'm rebuilding a Frogeye Sprite that was stripped by someone else. I cannot work out the route of the Speedo cable which runs from a takeoff point on the gearbox to the back of the speedo instrument on the dash. Does it go under/over the engine? How does it get through the firewall into the back of the speedo on the dash? Is it secured anywhere? Help!!!
