pop 103e
robo0121
PostPosted: Sat Jan 25, 2014 1:13 pm    Post subject: pop 103e Reply with quote
has anyone else on here just shut the door on their pop and the glass has broke in two.?? Shocked
PostPosted: Sat Jan 25, 2014 5:42 pm    Post subject: Reply with quote
Sounds like the wrong type of glass.
V8 Nutter
PostPosted: Sat Jan 25, 2014 8:32 pm    Post subject: Reply with quote
It was a common fault on V8 Pilots. If the door was slammed with the window have half way down the glass would crack from top to bottom, but it wouldn't actually break.
robo0121
PostPosted: Sat Jan 25, 2014 10:43 pm    Post subject: pop 103e Reply with quote
mine was fully closed and the glass fell into 2 pieces
Ashley
PostPosted: Sun Jan 26, 2014 11:02 am    Post subject: Re: pop 103e Reply with quote
Yes and just as I was setting off from Nailsworth to London mid winter and in a frost!
V8 Nutter
PostPosted: Sun Jan 26, 2014 8:38 pm    Post subject: Reply with quote
I don't know for sure but I would have thought your Pop would have had laminated glass which would crack, or less likely toughened glass which would shatter into crystals. As Peter said wrong type of glass.
