Posted: Tue Aug 19, 2014 7:50 pm Post subject: Brake Friction Material and Brake Pipe Material |
As part of my winter fettling and re-checking the Singer after a superb first year of running, I want to change the brake lines from master cylinder to servo and servo to main junction/union, what pipe is best to use? I am hoping to reuse the fittings off the current pipes. Should I just order the stock from Powertrax? (I have made pipes up many years ago, I have a good pipe bender and faring tool)
Secondly, when I originally recommissioned the Singer, I checked the pads and shoes but refitted them as they were ok. I have a set of new old stock, Ferodo rear shoes (probably asbestos based) but will need a set of pads in order to change both front and back brakes. Should I look for a set of new, old stock (asbestos based) or go with a new friction material?
BTW, I am fully conversant with the issues regarding asbestos and the need to wear PPE when dealing with the dust etc.
Kev |
Penguin45
Posted: Tue Aug 19, 2014 8:06 pm Post subject: |
I'd go Kunifer on the pipework and Greenstuff on the pads. DP2107 should be the set for your car.
Posted: Tue Aug 19, 2014 8:22 pm Post subject: |
Cheers for that P45
kev |
