Miken
Posted: Mon Nov 24, 2014 8:53 am Post subject: Wire size |
Im rewiring my old Morris 12v.
Can someone tell me the size (mm sqd) for the 2 wires that go to the ignition coil.
Ive done them in 1 mm . Now im thinking this may be incorrect.
Thanks
Mike |
Old Wrench
goneps
Posted: Mon Nov 24, 2014 9:47 pm Post subject: |
For cars with cotton-braided wiring Lucas employed standardised colours for particular purposes. Therefore, if you buy the correct colour cabling according to the original wiring diagram it should be of the correct cross-sectional area for the current.
Richard |
Dobbin
Joined: 15 May 2013 Posts: 67 Location: Central Scotland
Posted: Wed Nov 26, 2014 9:27 am Post subject: |
goneps wrote: | For cars with cotton-braided wiring Lucas employed standardised colours for particular purposes. Therefore, if you buy the correct colour cabling according to the original wiring diagram it should be of the correct cross-sectional area for the current.
Richard |
I'd be careful about relying on this now. Nobody is manufacturing cotton braided cable as per original any more; instead they take standard modern cable and apply braiding so it looks like the original. Obviously there's room for error with this approach, and you should bear that in mind. |
Miken
Posted: Fri Nov 28, 2014 9:43 am Post subject: |
Thanks for the replies. Im sorted now |
