Posted: Thu May 07, 2015 4:41 pm Post subject: |
Yes there will be plenty of pottering about
More progress today in the sunshine.....
Clutch & Flywheel removed, and I can conclude that the rear crank seal is leaking:
Front axle removed and ready for a clean up:
vitesse
Posted: Thu May 07, 2015 6:56 pm Post subject: |
Good progress Steve. It must be quite satisfying taking everything off and cleaning it up and bolting to that nice shiny new chassis.
Tony |
christine lowery
Joined: 30 Sep 2009 Posts: 496 Location: wallsend tyne and wear
Posted: Thu May 07, 2015 10:16 pm Post subject: |
we used to buy our landy tyres from
Dundee tyres ltd Carlisle airport
they but ALL the mod surplus stock
christine |
Posted: Sun May 17, 2015 8:16 pm Post subject: |
Thanks Christine, will contact them if I need some....
More rusty plates on the chassis held on with just seam sealer!!!
does anyone on here have experience of changing the crank rear oil seal on one of these?
Any advice welcomed |
vitesse
Posted: Sun May 17, 2015 9:56 pm Post subject: |
That's some bodge Steve. It's clearly someone in the past has tried to cover up that hole to fool either a MOT tester or a potential buyer.
I don't think morally I could do that sort of thing.
Tony |
Posted: Mon May 18, 2015 9:32 pm Post subject: |
He had a bit of a trim today
Posted: Tue May 19, 2015 12:00 pm Post subject: |
Clearly a short wheelbase LR.
Posted: Thu May 21, 2015 12:11 pm Post subject: |
If you keep taking bits off, this is what you end up with:
Engine was the second to last part out:
Earlier this week I delivered the bulkhead to be repaired and galvanised by these guys:
http://www.ashtreelandrover.com/About_Us.html
The very last part to be removed from the old chassis, was the steering relay.
It was most definately the most stubborn!
The official Land Rover workshop manual says you will need a brass drift to assist with removal.
After a few goes with that, I moved on to using a very large 3/4" drive socket as a pressing tool,
with my trolley jack under it against the weight of the engine,
but no luck.
After about 100 clouts with a large sledge hammer,
still wouldn't budge!!
In these situations the only option is cesarean section:
Not a princess I know, but I was very pleased
Posted: Thu May 21, 2015 3:18 pm Post subject: |
That certainly is a monster of an lever and bush. You would never have got that out with all the rust by the factory method.
Are you now going to rebuild the engine or is it clean up and re-assemble now? |
Posted: Thu May 21, 2015 3:46 pm Post subject: |
Lashings of copperslip will make removal of the relay a simple task in future years. Did the one on my previous lightweight and thankfully some kind soul had put a few brushfulls of copper grease which helped a huge amount.
Looking really good
Kev |
Posted: Thu May 21, 2015 9:18 pm Post subject: |
Cheers Kev, Peter, everything will be cleaned up and either painted or in some cases oily ragged as I am trying to avoid over restoration.....
The fuel pump (with it's glass filter), water pump, stat housing, heater valve, oil filter housing, and engine mount brackets will all be removed cleaned and painted
(if necessary) as they are all really crusty. While they are all off the block will be cleaned up and painted though I am not keen on that pale green which was original,
might go with satin black?
Also it needs a rear crank oil seal which involves removing the sump,
then once all that's done, it will be fitted onto new chassis.
Looking forward to that part!
Steve |
Posted: Thu May 21, 2015 9:36 pm Post subject: |
Won't satin black make it more difficult to spot any odd leaks that might develop? _________________ Bristols should always come in pairs.
Posted: Fri May 22, 2015 8:18 am Post subject: |
Penman wrote: | Hi
Won't satin black make it more difficult to spot any odd leaks that might develop? |
I reakon its a certainty that oil leaks will appear
Kev |
Posted: Fri May 22, 2015 10:10 am Post subject: |
Penman wrote: | Hi
If that were the case, surely Land Rover would have used satin black |
