Posted: Tue Mar 24, 2015 5:36 pm Post subject: |
Hi Kev,
Yes I had been looking at those, and the bushes and U bolts are included in the price if I have read it correctly?
Might end up doing that. Is the ride on the road a bit less bouncy, assuming the shockers are in good working order of course.....?
Cheers Steve |
Posted: Tue Mar 24, 2015 7:15 pm Post subject: |
Massive difference on road to be fair, i changed the shocks anyways but it felt almost coil like when done.
If you are getting them from a different source be careful as the quality varies between suppliers
Kev |
Posted: Tue Mar 24, 2015 7:29 pm Post subject: |
Best tip i had for changing the springs was to cut all the old bolts n shackels off using a slitting disk.
I also spent a bit of time packing the chassis up so it was perfectly level, made lining everything up a lot easier.
Kev |
Posted: Wed Mar 25, 2015 9:15 am Post subject: |
Thanks for the tips Kev, can you expand on "Lining everything up" please? When I refitted the rear leaf springs on my little Honda,
it seemed there was only one position to fit it all in, so no possibility of getting the springs / axle in the wrong position.
Steve |
Posted: Wed Mar 25, 2015 7:48 pm Post subject: |
Land Rover springs are somewhat more substantial than the bent paper clips found on lesser oriental vehicles _________________ Rover P2
Posted: Wed Mar 25, 2015 8:16 pm Post subject: |
Phil - Nottingham wrote: | Land Rover springs are somewhat more substantial than the bent paper clips found on lesser oriental vehicles |
True, I have found that the LR shackle is heavier than the Honda spring |
Posted: Wed Mar 25, 2015 8:49 pm Post subject: |
D4B wrote: | Thanks for the tips Kev, can you expand on "Lining everything up" please? When I refitted the rear leaf springs on my little Honda,
Steve |
Exactly what you say, so you can measure the position of the axles and double check everything.
My garage floor is dead level (used expensive concrete that freeflows and is very smooth) so by using a lazer level, i made sure the chassis was perfectly level.
All made the reassembly much easier.
Nothing beyond you considerable skills though.
There are a few overdrives for sale onthe bay!
Kev |
Posted: Tue Apr 21, 2015 4:59 pm Post subject: |
Landy now awaiting the arrival of new galvanized chassis
Posted: Tue Apr 21, 2015 5:13 pm Post subject: |
Nice work, looking forward to the rebuild
Kev |
Posted: Wed Apr 22, 2015 5:47 pm Post subject: |
Just got back from North Yorkshire after collecting the new chassis.....
277 miles each way.
Just setting off home:
Then with no one to help unload, where there's a will there's a way, even if it is a little off balance oops
Then out came the trusty skateboards to manouvre it into the garage!! |
Posted: Wed Apr 22, 2015 8:26 pm Post subject: |
Rick wrote: | You'll be on the road by the weekend! If only all old vehicles were so well supported, spares-wise.RJ |
Yep after that little Honda this is heaven for spares!
Think the weekend might be pushing it tho |
Posted: Mon Apr 27, 2015 4:33 pm Post subject: |
Back axle cleaned up and painted today:
I was told by a UK leaf spring manufacturer, that if I ordered the "cheap" springs from a well known Land Rover specialist,
that the left and right would be the same when in fact, the drivers side should be taller......
So here are the rear ones removed:
And here are the "cheap" ones, as at a 3rd of the price I thought I'd give 'em a go:
Drivers sides are taller but perhaps not as much |
vitesse
Posted: Wed Apr 29, 2015 10:05 pm Post subject: |
Wow those leaf springs should make quite a difference Steve, the old ones look a bit tired. I bet they weigh quite a bit? How do you fit them, do you attach one end then jack up the other end?
The chassis looks superb.
It will be as good as new once it's all back together.
Tony |
