Posted: Thu Apr 30, 2015 10:08 am Post subject: |
Hi Tony,
Yes the leaf springs are extremely heavy! The Fedex driver was very happy to get them off his van as they had been sliding around in the back wrecking all the other parcels!
That will teach him what those tie down loops are for.....
I removed the rear axle with springs still attached, so that was mega heavy, trusty skateboard managed to slide the whole lot out though,
and then the cutting disc on the angle grinder made short work of those rusted U bolts.
The Land Rover workshop manual speaks of using two trolley jacks to reinstall the back axle, one under the axle,
and another under the spring, should be fun!
Cheers Steve |
vitesse
Posted: Thu Apr 30, 2015 9:33 pm Post subject: |
I suppose it makes sense to have the engine and gearbox back in first to give you some weight to work against? |
Posted: Fri May 01, 2015 9:40 am Post subject: |
Last night I managed to "loosly" fit the rear axle and springs,
found my steel toecap boot useful at one point to raise the whole lot up just that little bit more |
Dipster
Joined: 06 Jan 2015 Posts: 408 Location: UK, France and Portugal - unless I am travelling....
Posted: Fri May 01, 2015 10:42 am Post subject: |
When I changed the rear axle on my Defender I was alone (actually in Morocco) without facilities other than what I had in the vehicle. I cheated.
I simply jacked the vehicle high enough to lower the assemble off with its wheels on, roll it out, fit wheels to the new one then roll it into place and lower the vehicle down jiggling the axle into place. Aligning up all the bolts was helped by my large, trusty, Thor hammer and the use of a couple of jacks.
I was knacked at the end of the day though. |
Posted: Fri May 01, 2015 10:57 am Post subject: |
Hi Dipster,
Great story! It might have been easier for me if I had fitted the wheels on the loose axle, just never occurred to me at the time. Doh!
Cheers |
Dipster
Posted: Fri May 01, 2015 11:30 am Post subject: |
One of the many pearls of wisdom my dear old Dad taught me was that you can do anything (well, almost) if the you give the problem enough thought!
First job was always put the kettle on and take a second. |
Posted: Fri May 01, 2015 2:03 pm Post subject: |
Posted: Wed May 06, 2015 6:57 pm Post subject: |
Yesterday, with some much appreciated help from my father, we removed the gearbox from the old chassis:
And some more progress today, with some reassembly at the rear:
Steve |
Dipster
Posted: Wed May 06, 2015 10:20 pm Post subject: |
It is looking great. Well done.
Did you choose the Goodyear G90 tyres? I used those and found then noisy but remarkably good, even on wet roads. I changed them when I noticed nasty looking bulges appearing in the sidewalls. |
Posted: Thu May 07, 2015 7:38 am Post subject: |
Wow, that's some fast work. Last ime I looked you were just unloading the chassis. It really is going to be a new Landy. |
Posted: Thu May 07, 2015 10:01 am Post subject: |
colwyn500 wrote: | Wow, that's some fast work. Last ime I looked you were just unloading the chassis. It really is going to be a new Landy. |
I'm trying not to make it "too new" though |
Posted: Thu May 07, 2015 10:05 am Post subject: |
Dipster wrote: | It is looking great. Well done.
Hi Dipster, I ended up with these G90's as the only seller I could find with a set of series steel wheel and tyres was Vass Ltd
http://www.vass.co.uk/
They have the look I wanted, but might not give me much service as I too can spy the signs of the odd bulge |
Posted: Thu May 07, 2015 12:34 pm Post subject: |
D4B wrote: | Dipster wrote: | It is looking great. Well done.
I put some retreaded 7.50x16s on y last lightweight from these:
http://www.kingpin-tyres.com/tyres/re-treaded-tyres/4x4/
They worked well in all weathers and were very good quality for the money.
kev |
Posted: Thu May 07, 2015 1:48 pm Post subject: |
Cheers Kev,
might have a look when funds replenish a little |
Dipster
Posted: Thu May 07, 2015 3:03 pm Post subject: |
If you only intend to potter about with the vehicle I think the G9os could last a fairly long time, even with the odd bulge. They are as tough as nails and almost stand up on their own without air! Not sure what an MOT tester would say though.....
I changed mine because I am often out and about in odd and remote places. I carry spares and tools that add quite a bit of weight to the vehicle. So I did not want to take a chance. |
